Results 1 to 12 of 12
    South Africa
    Default DCM 3.7 AP ecu read and write
    hi there all. i need some help in reading a ecu from gwm h5 vehcile. 2015 model 2l. the engine light is dead and coil light. vehicle not starting. secondhand ecu engine light comes on. which protocol should i use to read and write info from original ecu to seconhand ecu. i use ktag clone. many thanks in advance.
    South Africa
    Default gwm dcm3.7AP
    hi there. did pin out as per ktag instructions. refuse to read ecu. did 7 bridges on other side of board, no luck. please someone advise. many thanks.
    South Africa
    Hi. Any assistance please. Help will be appreciated. Thanks in advance.
    South Africa
    No help from anyone please? Thanks
    South Africa
    Hi members. Please should I return computer boxes due to difficulty to work on. Looks like Delphi ecu's are a headache. What would be the next move to get ecu programmed. Agents maybe?? Many thanks in advance.
    ohkarol's Avatar
    Oct 2010
    PL/UK
    you need a good geniue flashing tool to work with this ecu.
    bFlash/Kess/Ktag/CMD Master
    DPF/EGR/DTC/AdBlue/ChipTuning. ------>PM
  7. The Following User Says Thank You to ohkarol For This Useful Post:
    frikki (3rd August, 2020)
    South Africa
    Quote Originally Posted by ohkarol View Post
    Thanks friend. That's all I needed to hear. Will return ecu's. Many thanks.
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by frikki View Post
    on your photos you have choose dcm3.7 with protocoll 388 and mcu 72513...
    but on your ecu photo itīs an dcm3.7AP...
    it should be mcu72544...
    try other protocoll 1094/1096/1100/996/931...
    check out this one, if they support this mcu...
    but donīt know if itīs possible by clone...
  10. The Following User Says Thank You to figani For This Useful Post:
  11. #9
    South Africa
    Quote Originally Posted by figani View Post
    will have a look dear friend. thanks
  12. #10
    South Africa
    hi friend. i double checked. mcu is 72513 from original ecu. so i think selection is fine. maybe ecu dead. ktag cant pull a read from it. thanks
  13. #11
    br556hre's Avatar
    What kSuite you used to read with Ktag clone (what version do you have)? Did you manage to find out how to write with KTag clone?
  14. #12
    South Africa
    Quote Originally Posted by br556hre View Post
    hi friend. i didnt bother with that ecu any longer. i think i returned it to the customer.
