Page 1 of 3 123 LastLast
Results 1 to 15 of 34
    Nov 2011
    Default Mercedes Vito - w447 - NO Backlights in LCD
    a very common problem in Vito w447 / 2016
    No backlights working behind the middle LCD
    LCD work 100% and all other function work perfect
    Someone has repair info ?
    Thx
    rob h's Avatar
    May 2011
    I have one, just like this.
    Did you, or anyone figure out how to fix this?
    Dash still works, just very dimmed.
    Changing lcd, does not help.
    Plug in other cluster, that is fine.
    For now, we will exchange cluster.
    I also found this on dk.
    https://www.digital-kaos.co.uk/forum...highlight=w447
    Nov 2011
    Quote Originally Posted by rob h View Post
    did not find a solution yet
    has nothing to do with filter or similar can-bus elements.
    the problem is on the main board, thats for sure, but where......
  4. The Following User Says Thank You to CARPARTS For This Useful Post:
    rob h (30th July, 2020)
    rob h's Avatar
    May 2011
    Then i will swapp the hole cluster.
    Thank you!
    uk
    hi have same problem on 447 dash i know there is a fix out there anyone willing to share which component is to be changed,
    no filter on this one its common problem..
    rob h's Avatar
    May 2011
    Is this a Johnson control flaw.
    Are the vdo cluster better?
    salkapone's Avatar
    Oct 2013
    measure.............
    Recovery Service ,File Service [COLOR=#00ff00][FONT=system]VAG ,PSA,Renault ,FIat IMMO solutions!!BMW solutions!! Volvo solutions!! Audi BCM2 repair ,key programing .module matching !!MB solutions !!! CAS / FEM / BDC Recovery !! Poldiag Keymaster seller
    Nov 2011
    Quote Originally Posted by salkapone View Post
    give me picture of front side board (around mcu) il show u which components are problem !!
    here is the requested picture ....
  10. #9
    Jan 2017
    I have the same problem on my W447. Does anybody can tell me what to change please?
  11. #10
    credoline's Avatar
    Србија
    I have the same problem on W447 instrument cluster, display work but no backlight. I am contact minitools.com and they told me that problem is on main board. Anyone know where is problem ? I need to repair myself. I can not send it to outside country.
    Thank you
  12. #11
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by credoline View Post
    Thank you
  13. The Following User Says Thank You to drpeter For This Useful Post:
    credoline (17th August, 2021)
  14. #12
    credoline's Avatar
    Србија
    Both of transistors are okay, tested with component tester and also replaced. All resistors around them are also ok.
    Anythyng else?
    Quote Originally Posted by drpeter View Post
  15. #13
    Alawigmx's Avatar
    Aug 2016
    Sweden
    I had a similar error, I had ripped a small capacitor and its trace in top right corner of cluster (from back), repaired trace and checked continuity, all worked fine afterwards.
    Achtung
    Press the magic button
  16. #14
    POLAND
    I have the same problem. Anyone know the solution?
  17. #15
    Dec 2011
    Anythyng else?
    Hello ! I have same dash with same problem, bought new LCD but still no back light, but graphic and all working OK. Mine cluster dont have CAN filters or any of that. I've also heard about BCP53 replacement and component in surrounding , but nothing. Now Im re soldering all bigger resistors. Does anyone have solution, I have dash on my bench for testing.
    Best regards
    Alex L
