Results 1 to 5 of 5
    Jan 2018
    Default Renault CLIO 3 need help to make EPS (DAE) virgin
    Hi mates. Need some help.
    Got the car to alternator repair. After battery dissconnection i have DEF048 fault with immo data wrong from EPS.
    So now i need to make it virgin and code with clip.
    EPS unit number: 8200937950B
    Eprom is located under plate and i know there is solution to read and make it virgin in-circuit, But I can't find this points.
    Can someone help me with this?
    I have VVDI prog and there is scheme to connection to processor and option - erase, but as i found here - immo and vin are in eprom, not in proc.
    Jan 2018
    Photos from module
    May 2020
    hello,,in some cases renolink or ddt4all..makes eps virgin through obd ...the codification is maked by the car itself,first virgin the steering and then put the ignition on APC+ some time ,then cut the ignition few seconds and another time ignition APC+...after this procedure make a diagnostic with clip,erase faults and check the state of inmobilizer on injection and uch ..
    this procedure works on fluence and megane 3 with eps steering and card key ..i think is the same on clio 3 ..
  4. The Following User Says Thank You to JETRONIC1 For This Useful Post:
    VitalyR133 (3rd August, 2020)
    Jan 2018
    I have installed ddt4all but didn't managed to connect with eps. Just lack of time. I will try it tomorrow morning and hope it will be ok.
    As I see at another site there is a possibility to write Vin and crc check. But nothing about virgin.
    Отправлено с моего SM-N975F через Tapatalk
    Jan 2018
    Confirm, DDT4all make this EPS virgin through OBD. Done in 5 minutes xD
