Page 1 of 3 123 LastLast
Results 1 to 15 of 33
    Jun 2020
    Default Toyota Corolla Mileage adjust and opening cluster
    Hello every one,
    Can any one advice me how do I adjust the odometer on the Toyota Corolla 1.4 year 2006, if it on the chip how do I open it, and please see the pictures attached, thank you.
    Thank you
    wembleyhill's Avatar
    Feb 2009
    looks like you will have to remove needles and dial and will proberbly then find screws chip should be c56
    use buttons
    Jun 2020
    One of the other forums I read that any Toyota siemen Vdo Ag is done by OBD2, I'll try that and confirm, well looks like I tried pulling the needle from the temperature I herd click sound like I have broke some thing will see if that works after running car, the way its sealed I don't thing you can do any thing with it, good thing I never tried pulling the main ones though,
    Feb 2009
    what programmer you using not many tools can do toyota via OBD
    use buttons
    Jun 2020
    Its Digiprog 3, let see if it works
    Feb 2009
    good luck you'll need it
    use buttons
    Jun 2020
    well i plug in via OBD2 and its say no chip found, didnt work , and another thing is i cant even open this main thing is the needle are fixed not removable and yes i have broke the temperature needle some where in side when attempted to remove it , any other way i can open it the seimen VDO ag are diffuclt to open unless damaging some thing.
    Jul 2020
    In my experience with Toyota, you can not use obd 2 for mileage correction. Remove needles, access eprom and with the Digiprog 3, use either st01/st04 adaptors to read eeprom.
    Report back to us with dump
    Feb 2009
    Quote Originally Posted by stzmotors View Post
    not difficult to open straightforward job
    use buttons
    Jun 2020
    i know if the needle come of easy then removing the dial sticker and removing the screws behind it , but for some reason cant remove the needle.
    Feb 2009
    Try this https://www.youtube.com/watch?v=2vsZaryVhKo
    use buttons
  12. The Following User Says Thank You to wembleyhill For This Useful Post:
    stzmotors (5th August, 2020)
  13. #12
    May 2011
    hi
    with stool you can make it over socket...mbus
  14. #13
    Jun 2020
    Hello the update, I did the mileage correction on the Digiprog it reads and write OK, but when I plug every thing back to car the mileage from 79000 to showing 1175000,
    And another thing is that the revs and MPH doesn't work now ������.
    Any help please
  15. #14
    Jun 2020
    15965884408828591628812815686118.jpg here is the picture but it showing different on car
  16. #15
    Jun 2020
    HERE IS THE DUMP73000_93CS56.zip
