Results 1 to 3 of 3
    May 2016
    Default Renault Mascott 3.0 130Dxi - DTC 0089
    Hi guys
    I need make off error P0089 from ECU
    ECU is EDC16c41
    Renault Mascott 2007 3.0
    Can someone help to do it??
  2. The Following User Says Thank You to Gebaa For This Useful Post:
    McDowell (22nd September, 2023)
  3. #2
    Mar 2020
    in the field
    yu have to look for a fuel leak rather injectors
  4. The Following User Says Thank You to pawl For This Useful Post:
  5. #3
    McDowell's Avatar
    Feb 2019
    Zamunda
    Hello same problem here, I think it comes from ecu because car stops and it is sporadic. Do you know how to solve iit? i tired to resolder board without luck, maybe reballing mpc?
    Injectors are tested, fuel pump and sensrors ok.
