hello
jaguar x type 2002 petrol 3000 v6
I cant connect ecu, obd not power and no signal, all fuse it okay,
ecu aluminum cover oxidation see picture please, on pcb like good, ecu dead?
help please
hello
help please
Basically you can remove ECU from car and the power should still be coming to OBD connector number 16.
Ok
I have new ecu, how can I programming?
i did one off these a while back but don't remeber exactly what I did... have you tried copy eeprom of bad ecu to donor ecu... ???...
Hello
I try next week, read with ktag?
Which eeprom?
hello
I have new ecu programmed with ktag, engine have not cranck, engine not start, i read with launch pro3 all module, engine can not read, TCM fault P1797 Faultcode defective CAN TCM module, cluster fault code U1900 CAN comunucation fault
Help please
I think it's this eeprom you need to copy across.
PSAcars (3rd February, 2022)
Hello Paddjohn
I later report
