Page 1 of 16 12345611 ... LastLast
Results 1 to 15 of 240
    scotland clydebank
    Default Renault ecu tool 2.98
    Can somebody explain when
    We use this
    Feature on new software
    AES CRYPTO_KEY calculation from PINCODE for Dacia 2012+/Clio IV/Trafic III/Master IV/Twingo III
    Dec 2016
    Quote Originally Posted by godfathertre View Post
    We use this
    This function is not for us ! Developer just show to other developer ( AVDI Lonsdor AUTEL OBDSTAR ) that he can program used BCM , 2016+keys ..... but for 500€ he wan't ( https://www.emulatorshop.com/devices...coding-tool-en )
    For use it you need 1°)PIN code + 2°)AES TAG-KEY programmer
    1°) need to flash BCM ( maybe an risky job for RET ? they delete Trafic 3 key learning to 2.93 update )
    2°) 1500€
    for conclude , i'm ready to pay for an new tool , but if nothing move i will bought Lonsdor AUTEL just for new 2016+ Renault
  3. The Following User Says Thank You to TERMINATOR1000 For This Useful Post:
    godfathertre (17th August, 2020)
    Ecuprog31's Avatar
    Mar 2018
    Crypto key calculation from pincode ???
    if we have pincode we don’t need anything to learn key
    this option is useless
    Dec 2016
    Quote Originally Posted by Ecuprog31 View Post
    Yes , you don't test this function yet ?
    It's just for glory , they show that they can made " dealer key " ...
  6. The Following 2 Users Say Thank You to TERMINATOR1000 For This Useful Post:
    godfathertre (17th August, 2020), RIMKACHIP (15th August, 2020)
    RIMKACHIP's Avatar
    Feb 2012
    Good but why they don’t include twingo3 and trafic 3 aes key programming !! ?? If they will add this option it will be good.
    Envoyé de mon iPhone en utilisant Tapatalk
  8. The Following User Says Thank You to RIMKACHIP For This Useful Post:
  9. #6
    Dec 2016
    Quote Originally Posted by RIMKACHIP View Post
    For me , it's the time to read/write D-flash & risk to erase them , 20 min , for me it's an problem & i never take the risk if i don't have original CanClip + renault.net for repair an crashed BCM ...
    Trafic 3 & Twingo 3 will use AVDI method , need to made dealer key + "easy" read PIN code after viginize it ( same method they using for 2016+ Clio 4 )
    Megane 4 , Kadjar , Trafic 3 & Twingo 3 need AES tag-key programmer , it's actually the R.E.T problem ...
    AES tag-key programmer cost is under 100$ , just need to be integrated to R.E.T ( like this https://diagcode.com/renaultusb/ )
  10. The Following 4 Users Say Thank You to TERMINATOR1000 For This Useful Post:
    andreia67 (5th September, 2020), dzt1399 (11th September, 2024), frappes (23rd January, 2021), godfathertre (17th August, 2020)
  11. #7
    Jan 2016
    It will be also good to add Logan&Sandero Visteon UCH
  12. #8
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Before 2 or 3 months, last time I asked them in support...
    Answer was: it will be released fast...
    But what this fast means, don't know...
    I'm also waiting for Twingo 3/Smart 453...
  13. The Following 2 Users Say Thank You to figani For This Useful Post:
    godfathertre (17th August, 2020), RIMKACHIP (16th August, 2020)
  14. #9
    Dec 2018
    wait for the anniversary version 3, maybe it will contain new modules for working with the latest available cars
  15. #10
    Dec 2016
    Quote Originally Posted by Catalizator View Post
    waiting .... the problem is that the new cars are easiest than old cars & OBDSTAR already made Megane 4 cards programming since 18 months !!!!
    if Chinese beat it on Renault , VAG , EU cars ; this is the end of EU tools .
    In France , demand of 2017+ Cars represent one job / month , it's not an emergency update , buy another tool ( lonsdor autel obdstar ) just for Megane 4 Twingo 3 is not reliable for me because i have better covering with my other tools , i prefer buy 1500€ new Renault tool than invest in IM508 online
    AVDI is too expensive & online , better is waiting
  16. #11
    Dec 2018
    Quote Originally Posted by TERMINATOR1000 View Post
    what new tool for 1500 are you writing about?
  17. #12
    Dec 2016
    i hope an new "Reno eku told" , for new 2020 cars who need token !
    future is to lock OBD2 access by Renault.net , 2 solutions - direct access to BCM OR official token !
  18. #13
    Top Poster maxim200's Avatar
    I tried to program the card for Laguna III, the ecu tool connected to the UCH without a problem, but there was a problem as seen below. anyone had like that?
    [11:38:08] Status : Waiting For Commands
    [11:38:11] Status : Finding USB Device Status: OK
    [11:38:12] Status : Connecting UCH by CAN...CONNECTED
    [11:38:12] Status : Reading UCH Identification...DONE
    [11:38:40] Status : Gaining security access 2...SENDRESP ERROR_35
  19. #14
    RIMKACHIP's Avatar
    Feb 2012
    Remove card and ignition off before programming card ?
  20. The Following User Says Thank You to RIMKACHIP For This Useful Post:
    godfathertre (11th December, 2020)
  21. #15
    castin's Avatar
    Oct 2015
    Last time im program add card for Clio IV 2018. Use option "read pin code for car >2015" (must hawe one working card). Clear HFM, learn ISK from working card and then program second card (Hitag AES).
  22. The Following User Says Thank You to castin For This Useful Post:
    godfathertre (18th January, 2021)
