Results 1 to 15 of 15
    super jumbe's Avatar
    Livingstone
    Default Yaris 2004 any one succeeded KEYDIY remote.
    I have Toyota Yaris 2 button remote ref: 09071-0D020 any one succeeded with keydiy remote? 3d asking over 100 for new key, they not cheap, will able to save some dole car belongs to my ex....
    rob h's Avatar
    May 2011
    You mean 89071-0D020
    89070-47100 yaris 1999-2004
    2005+ 89071-0D030
    or try
    89071-05010
    89071-0D010
    Toyota 50171
  3. The Following User Says Thank You to rob h For This Useful Post:
    super jumbe (23rd August, 2020)
    Livingstone
    Thanks rob looks you not shore will have to try all off them as you say.
    rob h's Avatar
    May 2011
    If you open the app, look for 89071-0D030.
    Then read the feedback: Yaris 2003 ok.
    If you are not sure. Soon as you have it in prog mode, there is time to try a few.
    oem info
    89071-0D020
    VALEO 736716-A CE 523
    Toy47 blade
  6. The Following User Says Thank You to rob h For This Useful Post:
    newone's Avatar
    Oct 2016
    89071-0D020 has anyone succeded with kd or xh?
  8. #6
    rob h's Avatar
    May 2011
    About the Yaris key, i use oem keys.
    Not easy to get.
    I tried all possible Toyota keys, in both Xhorse and Keydiy. None worked.
    89741-0D020 is the Yaris 2003-2005 reciever
    And these keys:
    89071-0D020
    89071-0D050
    89071-0D060
    89070-52081 vvdi-online works well on a Yaris verso 2005.
    compatible keys
    89070-52081
    89070-47101
    89070-52021
    reciever
    89741-52020
    89741-52021
  9. #7
    Mar 2018
    UK
    Quote Originally Posted by newone View Post
    KD work must generate 0D030 online
    XH not work
  10. The Following 2 Users Say Thank You to Manta1600 For This Useful Post:
    newone (7th January, 2024), rob h (7th January, 2024)
  11. #8
    Jan 2017
    Netherlands
    Try 89071-0D010 - KDY - did a verso from 2005 and that went ok - in reactions of feedback think also lot of positive for earlier Yaris. It is not always same version I noticed. If i'm not sure I generate a simulation and try learning with that before making real one. Last few weeks had several but not 100% sure or normal Yaris was in that batch (most are Verso)
  12. The Following User Says Thank You to Matronix For This Useful Post:
    wuza (8th January, 2024)
  13. #9
    Mar 2018
    UK
    Quote Originally Posted by Matronix View Post
    0d010 not work on 2003-2005 facelift Yaris
  14. #10
    rob h's Avatar
    May 2011
    Only if you check, what reciever is in the car, you will know 100% what remote should work.
  15. #11
    Mar 2018
    UK
    Quote Originally Posted by rob h View Post
    No it's a very clear what remote must use only when you see the car
    old shape Yaris up to 2003 use 0d010 with 4C
    facelift 2003-2005 use 0d020 with 4C
    new shape 2006-2011 use 0d030 with 4d70
    Yaris Verso use 0d010 4C to the end of production 2005
    0d020 and 0d030 are the same remotes just the chip inside is different
  16. The Following 2 Users Say Thank You to Manta1600 For This Useful Post:
    rob h (10th January, 2024), super jumbe (15th January, 2024)
  17. #12
    Apr 2016
    I've managed to generate 0D030 remote, but I didn't manage to adapt it to the car. It cycles lock/unlock 2 times. Spent about 20 minutes pressing buttons, but remote doesn't work...
  18. #13
    Mar 2018
    UK
    Quote Originally Posted by alkaskad View Post
    XH not work under 0d030 its wrong generate 0f060
    KD work but not always from the first time as the original remotes - must keep pressing the buttons until the central locking answer just with one cycle - if answer is two cycles is not programmed and must continue to press the buttons
  19. The Following User Says Thank You to Manta1600 For This Useful Post:
    alkaskad (10th January, 2024)
  20. #14
    Mar 2018
    hello 2006 Yaris 89071-05010 was successful.
  21. #15
    Sep 2022
    South Africa
    Toyota 50171 works for me every time.
