Hi everyone.
Can someone fix me this file please (DF002)?
It is Modus 2004 LHD
TRW 8200 433 516 D
50300785
(24c16 visible on upper side)
If you have virgin file is also OK.
Clio DAE file doesn't work....
Hi everyone.
TRW 8200 433 516 D
50300785
this is type 1 ,should work,try and report.
marsete (7th September, 2023)
Thanks for file but it isn't ok.
There is no DF002 anymore everyting is "Green" but steering is still not working. There is red STOP on dash but no dtc anywhere.
If I try to do steering angle calibration it reports that not all contitions are met, but I'm shure they are all OK. I tried with engine on or off...
One other thing ...When i diagnose with Clip all parameters are still (not changing) Voltage, steering angle...
On other ecus voltage changes when rpm changes ... here it stayes the same as when ignition was turned on.
Try this file, is virgin and DF002 correct.
Thanks Josue
This file is identical to the one from lesakljucevi....
DAE ecu behaves like it is locked... but no dtc-s
Is there maybe any checksumm to be done on this file ?
Good morning, I have tried several times that file and the program I use already does the checksum when you save the file, it is likely that you may have another problem in the fuse box. The question is, are you using the original DAE or is it a second-hand one? If it's second-hand, does the car start you with the original?
test this one........................
need help
now my goal is to buy xp-005
who will help?
Thanks rafal
That did it !
Now it works.
I just neded DF002 cleared. I found and fixed the reason for df002 but couldn't fix eeprom.
Thanks again for help.
Well done.......
need help
who will help?
Can anyone help with fixing DF002 in eeprom for renault modus 24c16 attached.
I tried to fix but:
version 1) the engine starts until I disconnect the battery, then no synchronization immo UCH - power steering;
version 2) the engine always start, but the steering angle cannot be programmed
HELPHELP
tray and report back
