    italy
    Default PROBLEM WITH OLD BMW MRSZ3 TEMIC
    hi, i've problem with old mrsz3 temic for bmw z3
    number it's 65.77-8386192
    i try to read and clear crash data with carprog programmer.
    on beanch an in car i've seme problem.
    i can read errors butwhen i try to clear crash data carprog says thet it's temic ecu and it's possible clearing data only on board, but i'm on board!
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. On board ( soldering to pcb directly, on bench ), I think this is what they mean.
    italy
    Quote Originally Posted by PSAcars View Post
    but in carprog instruction i haven't pinout for connect directly on pcb.
    i try on beanch with instrution to connect k line and alimentation but it's the same as on the car
    italy
    i will try to read directly mcu
    italy
    solved with reading mcu directly
    Jul 2019
    Italy
    hello can you gimme a pinout to read it? got same ecu.
    tks a lot!
