    Jul 2018
    Default Mazda 5 2.0 dpf off
    Hi guys i have a small problem I need to off dpf in Mazda 5 2.0d so I ask one of are forum member to switch off in map , I know that before write need reset dpf and reset oil , and then dtc then write a file . After write was ok for about 1 miles then same problem dpf regeneration and comulaction ash dpf
    Can you please tell me what I do wrong also I upload two file orginal and dpf off so some can check if there are ok thank you
    DENSO RF7x
    HW: RFAR18881
    SW: SW-RFARE0000.HEX
    Johnsy1998's Avatar
    Oct 2019
    United Kingdom
    Try this... Pass in PM
    Chiptuning File Service 24/7
    Thanks+Rep If I helped you!
  3. The Following User Says Thank You to Johnsy1998 For This Useful Post:
    szczapek1996 (28th August, 2020)
    Jul 2018
    Thanks can you please send me pass , do I do it right delete all dtc and oil service then write
    May 2020
    tot557545@gmail.com
    szczapek1996
    Hi help you good original worked dpf off solution,no chk.chk calculate tool
    for dpf+egr off solution ,EGR PLUG DISCONNECTED
    REP + THNX BUTOON FOR HELP
    Sep 2011
    Hi guys
    I need to off dpf in Mazda 6 2.0d so I ask one of are god member to switch off in map
    Can you help me also I upload the file orginal.
    Member Justeloo's Avatar
    Jun 2019
    Northern Ireland
    Quote Originally Posted by ecuprogramer View Post
    szczapek1996
    Hi, can i get pass this file? Thank you
