Results 1 to 5 of 5
    Dec 2018
    United Kingdom
    Default MED9.1 Audi damos/kp file needed or help with locations
    Hi all,
    i have an Audi A3 2.0 tfsi med9.1 and i cant seem to find a relative map pack/damos/kp to suit my ecu. ive tried similar ones but the map addresses are either nowhere near or a different byte value.
    i had a stage 2 map put on this by a local tuner and would like to compare from an original to stage 2 or if possible someone to see if its had a good map or a typical bad map.
    HW : 0261S02341
    SW : 1037386817
    Upg. SW 8P0907115K 0040
    im only using winols 2.24 to entice me in before i purchase original and i know later version damos/map packs etc wont work with lower versions.
    any help would be most appreciated
    my file should be attached here
  2. The Following User Says Thank You to shaneyballs69 For This Useful Post:
    Amad375 (30th May, 2021)
  3. #2
    Apr 2019
    Default KP
    This should work.
  4. The Following 5 Users Say Thank You to Joshox3 For This Useful Post:
    accodinguk (23rd September, 2022), Amad375 (30th May, 2021), ferval (8th February, 2025), Maroka (25th March, 2022), tutzu (30th November, 2021)
  5. #3
    Dec 2018
    United Kingdom
    Perfect mate helped a lot, thank you very much
  6. #4
    Aug 2020
    Hi Mate,
    xxxxxxxxxxxxxxxxxx
    Thank you.
    Quote Originally Posted by Joshox3 View Post
    This should work.
    hi mate,
    can i have this kp please?
