Results 1 to 11 of 11
    Jul 2015
    My Car
    Default pinout hfm clio IV
    hello,
    i have clio IV all key lost and i need to read hfm for programming key, the priblem is the pinout in the manual of AVDI is not the same that i have.
    if anyone can send me pinout of this HFM
    thanks in advance.
    Jan 2019
    France
    same pinout on Renault Ecutool website, what programer do you use?
  3. The Following User Says Thank You to red69 For This Useful Post:
    adjee (24th September, 2020)
    Jul 2015
    My Car
    Quote Originally Posted by red69 View Post
    i have AVDI ( ABPROG), VVDI PROG, XPROG, UPA, ... BUT this pinout is not the same.
    Sep 2015
    Hello do you have pinout for this HFM clio 4 Thank's
    rob h's Avatar
    May 2011
    The wiring diagram, vvdiprog, is in the Menu. After you connect. It might fail to read.
    Then select the correct mcu, in mcu menu, to read.
    And iif you ever struggle to find a connection:
    Simpl find another unit, like a airbag.That is listed in both tools. With the same mcu,
    And compare these. It is often the quickest way, to find a suited connection.
    Sep 2015
    Pinout in vvdi is not same as this HFM
    rob h's Avatar
    May 2011
    It depence, what programmer you use, where you make the connections.
    These hfm boards are all the same.
    lion0304's Avatar
    Oct 2014
    Here is the right pinout
  10. The Following 9 Users Say Thank You to lion0304 For This Useful Post:
    Col19 (27th February, 2025), Fallen (12th March, 2024), Holmae (7th March, 2024), lesakljucevi (7th March, 2024), Louislesinge (7th March, 2024), rafal (7th March, 2024), rokibar (7th March, 2024)
  11. #9
    rob h's Avatar
    May 2011
    Wrong!
    This is orange5 connection, not a vvdiprog.
    Txd rxd are swapped on orange5 pinouts.
    Like i wrote before, all boards are the same.
    It all depends on the prog you use.
    You guys will figure it out.
    hertz, bdrate,
    If you dont state what prog you use, or need to use , all post are useless.
  12. The Following 2 Users Say Thank You to rob h For This Useful Post:
    Holmae (11th March, 2024)
  13. #10
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by rob h View Post
    Wrong!
    hertz, bdrate,
    I've made myself and use VVDi prog to read. Diagram from me and TESTED.
  14. #11
    rob h's Avatar
    May 2011
    You are correct, if i look closer, is see, you use 2 different solder spots, that non off the others use.
    Even the vvdiprog manual uses the common spots.
