Hello Gyus
I have radio Clarion PN-2805F from Qashqai. When I put in Juke, I have info on LCD "please init" . Anyone help me with remove this?I have bin from eeprom.
Hello Gyus
Ok. If anyone need help for this radio i will help. Remake the soft and it works
I need it, I made immo off (code off) but on car shows Please Init
Here ori dump
Tnx
P.S. Or need to press some buttons to enter code?
EQ1-4 GND............
With radio ON, hold button 4 and press power twice.
try 12 pin from connector top left to ground
budata (26th January, 2023)
Connectors like image
Anyone?
Still not solved.
its work with me
00300 5A 5A 12 27 7F 0D 28 96 02 00 00 01 00 03 FF 3C So then insert the jumper and turn on the device. Check.
61 C4 0E A8
5A 5A 12 27 7F 0D 28 96 00 00 00 01 00 03 FF 3A
this is how a new one is made to bind to the car.
61 C4 0E A8
snayperss1 (30th May, 2024)
This 00 is renew immo (reset) I opened again and found pin12 and will try to gnd. By schematic its say N/C pin
Hope there is cable on connector to cut and connect to gnd without opening radio 4th time
Wbr
