Results 1 to 8 of 8
    Jan 2019
    United Kingdom
    Default PSA SID208 ADVICE PLEASE
    Hi Guys
    looking for some advice
    was cloning a SID208 PSA, read data org ecu all ok, connect to new ecu and erase p-flash and try to write - failed as sectors not blank
    ECU is dead as i believe password has been erased
    tool used: HEXPROG - MICROTRONIK
    Is there any way to revive this ecu? It has a SAK-TC1797-384F150EAC MCU, Would i need to replace it and the ecu will have communication again?
    any advice from professionals appreciated
    thank you
    exxl's Avatar
    Jun 2009
    Bosnia-Herzegowina, Bos. Krupa
    I assume you tried cloning with hexprog in factory mode without boot pin? If so, try to boot the ecu you should have communication in boot mode with the ecu
    Poslano sa mog SM-G975F koristeći Tapatalk
    Jan 2019
    United Kingdom
    Quote Originally Posted by exxl View Post
    yes tried using factory mode, then tried boot mode 12v 2a but still nothing
    ---- SOLVED ----
    for everyone in future to avoid a big headache
    for SID208 use boot mode it is less risky
    power supply must be 14v or higher otherwise forget about it you not reading this ecu safely
    hex didnt erase the password in factory mode, it just didnt have enough power supply to write the ecu
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by amar28 View Post
    ---- SOLVED ----
    14V is not important, even on your car sometimes have only 12V and or less, and car starts and also your ecu...
    the most tool companies write in theier manual 5A should be enough for powering up such an ECU, same problem on simos...
    but sometimes 5A is not enough, and I put 10A and or an car battery...
    number7hd's Avatar
    Dec 2013
    Did You bring SID 208 back to life? After increasing power supply You could write flash again?
    If my solution helped You - do not forget to THANKS !!!
    Jan 2019
    United Kingdom
    Quote Originally Posted by number7hd View Post
    Yes correct
    Jan 2019
    United Kingdom
    For me battery booster did not work even in boot mode
    up until 14v i could not do nothing, the org ecu i had read with lower power supply but not the ecu i was cloning onto
    have had this problem in ktag before with ford sid208, 12v 2a or 3a can rarely read this ecu
    this is my input and experience of what worked for me
    HIGH VOLTAGE
    HIGH VOLTAGE
    I need some info about hexprog and sid208, can i read it in factory mode with good supply or not, did you have to swap some resistors in power module or not,
    Thanks in advance
