Results 1 to 3 of 3
    GERCOMOTIVE's Avatar
    Jun 2018
    spain
    Default DF038 RENAULT MASTER EPPROM DEFECT
    Hello friends, someone knows solution for this fault code.
    It is a Renault VELL SATIS with the code DF038.
    the truck is good, only the fault light comes on.
    Does anyone know how to translate this code to PXXXX so I could remove it from the flash.
    ecu bosch 0281 012 485 edc16c3
    Thank you very much in advance
       If my information served to help you, please click on THANKS + REPUTATION!!!!!
    Jun 2018
    spain
    The file is from a renault vel satis, although I accidentally saved it under the name renault master.
    Jun 2018
    spain
    Does anyone know something in relation to this fault?
