hi
if possible immo off EDC16C8 281011228 IVECO PN.69003185
thank you
hi
thank you
you must disconnect immobox
galaxy0634 (9th October, 2020), orx (5th October, 2020)
thanks , sorry file is a .bin ?
hi
dump is ok! remove immo box
regards
Please dear members push the button thanks and reputation button(stars)
do you need help? fill it in !!!
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
ECU type and number:
Memories :
https://www.digital-kaos.co.uk/forum...63#post1660863
hi
error DTC51???????
try to return the immobox! so start the car and look at the differences, return my dump, try to lock the eeprom with the up! that eeprom is subject to failure, maybe replace it! or simply cover with led
regards
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
Memories :
orx (6th October, 2020)
ok thanks already tried with install and remove immobox but always dtc51 ..anyway i've a doubt maybe eeprom is faulty , in alternative immoff it is also possible to solve in bdm ?
hi
what is a malfunction dtc 51?
try this
regards
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
Memories :
nothing bro always DTC51 Code92 ..generic error.
for me mean faulty eeprom but anyway i've used programmer ezp19 set to eeprom 25640 because 95640 is not supported.
now i'm tryng with KTAG but my Daily 50c17 edc16c8 with eeprom 95640 is not supported only 95320.
solve with IPROG V84 no more light check engine (error dtc51) , write with Skens .bin .
