Results 1 to 14 of 14
    Oct 2018
    Default MIB STD2 PQ +nav Bootloop.
    Hello there ,need help with MIB STD2 PQ +nav SW0363 HW31 ,i got it with bootloop VW Logo ,im try flash it in emergency mode ,but still again bootloop with logo ,attached part of log from PuTTY:
    -Welcome to TechniBoot-
    SVN Rev: 579332
    J5e.M30.LoadImage.ready: 0x0422E139
    J5e.M31.LoadImage.ready: 0x04FF54F1
    J5e.QNX.LoadImage.ready: 0x1E8044EE
    CPU0: L1 Icache: 512x64
    CPU0: L1 Dcache: 512x64 WB
    CPU0: L2 Dcache: 4096x64 WB
    CPU0: VFP-d32 FPSID=410330c3
    CPU0: NEON MVFR0=11110222 MVFR1=00011111
    CPU0: 413fc082: Cortex A8 rev 2 600MHz NOALIGN
    Loading IFS...done
    System page at phys:840f4000 user:fc404000 kern:fc404000
    Starting next program at vfe051524
    cpu_startnext: cpu0 -> fe051524
    VFPv3: fpsid=410330c3
    coproc_attach(10): replacing fe081910 with fe0810cc
    coproc_attach(11): replacing fe081910 with fe0810cc
    Welcome to QNX Neutrino on the Texas Instruments J5 ECO MIBSTD2NAV_MAIN Board (ARMv7 Cortex-A8 Core)
    Thu Jan 01 00:01:00 UTC 1970
    add net default: gateway 10.200.1.2
    J5e.QNX.init.ready
    Waiting for i.MX...
    Unable to access /net/imx6/tmp/main-startup-no
    Current core file directory: /tmp
    abcdefghijklmnopqr>ABCDEFCC:0x00000000
    SC:0x00000000
    HC: 0x00000000
    GH>s>J5e.imx6.start: 0x01D32AC9
    Aug 2015
    i have same error could you fix it?
    dec123ua's Avatar
    Nov 2015
    Kiev, Ukraine
    try to update firmware via emergency mode
    GB
    Hello I have the same problem, MIB STD2 PQ + NAV SW 0359 HW H 31 5C0035680D VW AMAROK 2017, any solution?
    Aug 2018
    Contact you seller software for support is easy
    Mar 2021
    Sir how to put unit emergency mode?
    Oct 2018
    Quote Originally Posted by mesutkb View Post
    https://drive.google.com/file/d/1odJ...ew?usp=sharing
  8. The Following 3 Users Say Thank You to Mikle1 For This Useful Post:
    angmar (20th May, 2021), audiopoint (9th June, 2022), catalinosonesti (23rd May, 2021)
    Oct 2018
    Hi ,are you have converter uart to usb ?
  10. The Following 2 Users Say Thank You to Mikle1 For This Useful Post:
    angmar (20th May, 2021), catalinosonesti (23rd May, 2021)
  11. #9
    GB
    Quote Originally Posted by Mikle1 View Post
    Hi yes
    Enviado desde mi moto g(6) mediante Tapatalk
  12. #10
    Oct 2018
  13. The Following 3 Users Say Thank You to Mikle1 For This Useful Post:
    angmar (3rd January, 2022), catalinosonesti (23rd May, 2021), SasaZg (31st January, 2022)
  14. #11
    Feb 2022
    hello , please help me. I have mib std2 pq plus , problem - bootloop on logo after try to backup emmc . Have log from imx6 serial:
    SVN Rev: 650763 - Nov 21 2017 / 22:49:12
    Variant: PQ stdPlus sop4 1GB LPDDR3
    CAAM: CAAM_CSTA 0x00000202 - trusted Mode
    CAAM: init -> ok
    CAAM: open already instantiation ring 0!
    CAAM: open ok
    Image verified
    CAAM: clock 0x00018900
    type=00000004, cksum=000074A5, address=10800000, length=002A2B61
    type=00000006, cksum=00000006, address=10800000, length=00000000
    iMX6.QNX.LoadImage.ready: 0x0F715A7F
    Enabling only 1 CPU
    L2 cache enabled
    CPU0: L1 Icache: 1024x32
    CPU0: L1 Dcache: 1024x32 WB
    CPU0: VFP-d32 FPSID=41033094
    CPU0: NEON MVFR0=10110222 MVFR1=01111111
    CPU0: 412fc09a: Cortex A9 MPCore rev 10 792MHz
    Board version: PQ/3 v19
    Detected i.MX6 Solo/DualLite, revision TO1.3
    PLL1 - System : 792MHz
    PLL2 - System Bus : 528MHz
    PLL3 - OTG USB : 480MHz
    PLL4 - Audio : 36MHz
    PLL5 - Video : 339MHz
    PLL7 - Host USB : 480MHz
    PLL8 - Enet : 100MHz
    IPG clock : 66000000Hz
    IPG per clock : 66000000Hz
    UART clock : 80000000Hz
    CSPI clock : 60000000Hz
    AHB clock : 132000000Hz
    AXI clock : 198000000Hz
    EMI_SLOW clock: 19200000Hz
    DDR clock : 396000000Hz
    USDHC1 clock : 198000000Hz
    USDHC2 clock : 198000000Hz
    USDHC3 clock : 198000000Hz
    USDHC4 clock : 306580644Hz
    ENFC clock : 24000000Hz
    System page at phys:10010000 user:fc404000 kern:fc404000
    Starting next program at vfe056b84
    cpu_startnext: cpu0 -> fe056b84
    VFPv3: fpsid=41033094
    coproc_attach(10): replacing fe073244 with fe089dd4
    coproc_attach(11): replacing fe073244 with fe089dd4
    Welcome to QNX Neutrino on the Freescale i.MX6 MIBSTD2PLUS_CPU (ARMv7 Cortex-A9 Core)
    00:00:00.213 [Info] [tsd.mibstd2.hmi.anim.cpp] [PERF:0xd773bf:IO0] iMX6.earlyRVC.ready
    00:00:00.214 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda start
    00:00:00.216 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: graphics init
    00:00:00.255 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: graphics init complete
    00:00:00.278 [Info] [tsd.videocapture.control] All rvc libs loaded successfully!
    00:00:00.280 [Info] [tsd.mibstd2.hmi.bootanim.j5] initialize video capture complete
    00:00:00.281 [Info] [tsd.mibstd2.hmi.bootanim.j5] mmap_device_memory successed
    00:00:00.281 [Info] [tsd.mibstd2.hmi.bootanim.j5] [PERF:0x11c8ab6:IO0] iMX6X.screen.start
    00:00:00.282 [Info] [tsd.mibstd2.hmi.bootanim.j5] try to load screen-mgr.so
    00:00:00.282 [Info] [tsd.mibstd2.hmi.bootanim.j5] watching_thread started
    00:00:00.284 [Info] [tsd.mibstd2.hmi.anim.cpp] Startup Info Thread started.
    00:01:00.010 [Info] [tsd.mibstd2.hmi.bootanim.j5] applyCSCGamma() r: 0xffff g: 0xffff b: 0xedff
    00:01:00.010 [Info] [tsd.mibstd2.hmi.anim.cpp] startup container mapped to addr 0xffde0 (length = 1048576)
    00:01:00.056 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
    00:01:01.129 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
    00:01:01.257 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
    00:01:01.450 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
    00:01:01.642 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
    00:01:01.834 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
    00:01:03.116 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
    00:01:03.260 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
    00:01:03.388 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
    00:01:03.516 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
    00:01:03.660 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
    00:01:03.789 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
    00:01:03.917 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
    00:01:04.045 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
    00:01:04.173 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
    00:01:04.301 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
    Unable to access "/dev/hd0" (2)
    chkqnx6fs: unable to access '/dev/hd0t177' - No such file or directory
    chkqnx6fs: unable to access '/dev/hd0t177.1' - No such file or directory
    chkqnx6fs: unable to access '/dev/hd0t177.2' - No such file or directory
    fsstate: chkqnx6fs took 0 seconds.
    mount: Can't mount / (type qnx6)
    mount: Possible reason: Invalid argument
    mount: Can't mount /tsd/etc/swap_keys (type qnx6)
    mount: Can't mount /tsd/var (type qnx6)
    iMX6.QNX.init.ready
    on: No such file or directory (/tsd/bin/system/startup)
    00:01:05.607 [Info] [tsd.videocapture.decoder] Reset Decoder!
    00:01:05.704 [Info] [tsd.mibstd2.hmi.bootanim.j5] Initialization of CaptureUnit and decoder done
    please tell me , are my emmc chip is dead? Thank you
  15. #12
    May 2017
    These are the worst ~~~~ing instructions ever. They were written by a 5-yr old.
  16. #13
    dec123ua's Avatar
    Nov 2015
    Kiev, Ukraine
    definitely
  17. #14
    Jul 2023
    Hi everybody!
    I have the same issue on my device.
    5C0 035 680 F - SW 0475 HW H41 12/19
    MIB STD 2 PQ +/NAV
    I get the following message from Putty if I start the device:
    SVN Rev: 626459
    J5e.M30.LoadImage.ready: 0x043770C7
    J5e.M31.LoadImage.ready: 0x0516C9D9
    J5e.QNX.LoadImage.ready: 0x1EF5E852
    Loading IFS...done
    System page at phys:840f5000 user:fc404000 kern:fc404000
    Starting next program at vfe05160c
    cpu_startnext: cpu0 -> fe05160c
    coproc_attach(10): replacing fe081d90 with fe08154c
    coproc_attach(11): replacing fe081d90 with fe08154c
    Welcome to QNX Neutrino on the Texas Instruments J5 ECO MIBSTD2NAV_MAIN Board (A RMv7 Cortex-A8 Core)
    J5e.QNX.init.ready
    Waiting for i.MX...
    I have started in emergency mode (2). With SD card and new firmware -
    Release = "MST2_EU_VW_PQ_P0478T"
    First question: It that the right sw?
    If yes, is that the right structure on the card?
    I have the following structure on the FAT32 SD card:
    bluetooth
    cpu
    cpuplus
    front
    main
    mainplus
    powerc
    prox
    touch
    metainfo2
    How could I identifier a hardware damage on the board?
    What can I do to start the update via SD card in emergency mode?
    Thanks in advance.
