Results 1 to 7 of 7
    Jan 2016
    Default peugeot 406 bsi swap
    hi to all,
    car : Peugeot 406 Coupé (8C) 2.9 V6 24V benzin
    engine code : ES9J4; XFZ
    BSI : s108551400 - 9637436480 siemens D9 B4
    I need to replace ori BSI ( broken ), I do have donor bsi with same partnumbers, can I just swap eeprom ( 93c66 ) of need more ?
    and how to read/write 93c66 ? as 8 bits or 16 bits
    Thanks for your time
    Gammoudi's Avatar
    Dec 2017
    ECUS
    YES SWAP WITH 16 BIT READ
  3. The Following User Says Thank You to Gammoudi For This Useful Post:
    mrchip (9th October, 2020)
    Jan 2016
    thank you very much,,,good evening
    YCFYCF's Avatar
    Nov 2019
    SL
    just de solder original eeprom 93c66 and sold to the new BSI
  6. The Following User Says Thank You to YCFYCF For This Useful Post:
    mrchip (11th October, 2020)
    Jan 2016
    Hi I have read C663CM3 ( st 93c66 ) from Ori broken BSI,, but dump looks strange like it's corrupted or previously edited by someone else, customer says car start with this ori bsi, I dont see any VIN numbers or Pin in dump or other information like as mileage , car is by year 1999 , please check my dump ! I wanted to clone ori bsi to donor but i don't trust this dump is OK, car is far a way, what can I do in the case if dump is corrupted, need to telecode after Virgin programming ? or just need virgin file and set mileage to "0 km " ?
    I tried to read first 93c66 on board with CarProg SOIC8 clamp ( without succes ) , after that desoldered and readed by TL866,, and again by Xprog
    dump is in attachment
  8. #6
    rafal's Avatar
    UK - PL
    here correct one bsi file.............maybe will help you
    pin: 1C2S
    need help
    now my goal is to buy xp-005
    who will help?
  9. The Following User Says Thank You to rafal For This Useful Post:
  10. #7
    Jan 2016
    Thank you Rafal ,
    can someone check my ori file please ! I found on other forums 2 file's , these file looks like my file ( without vin and pin ), I am now doubting if my file is really damaged , customers says also car start now with this dump.. if it is corrupt can someone share an Virgin file please ? and how can I find ori pincode , where is it stored more ( in ECU ) ?
