Results 1 to 4 of 4
    Default toyota corolla 2002
    Hi mates,
    I have 2002 toyota corolla with ecu 89661-02750 with immo chip inside 93c56 and key 4c chip
    The car does not start due to immo problem,I have tried to make a new key with zedfull but it did not start.
    Please I need your help with immo off if is possible for this ecu (with or without emulator)or even by writing the key data inside the eeprom,or a synchronization file...just any possible way to start this car.
    Thanks in advance,
    best regards.
    can anyone help with this issue please?
    rafal's Avatar
    UK - PL
    write this file
    insert master key - switch ignition on and wait 10 sec , then other same if have - car should start
    report.............
    need help
    now my goal is to buy xp-005
    who will help?
    Nov 2016
    do a immo sync with ecu
    1- turn key off
    2-connect pin 4 and 13 in obd socket
    3- turn key on position II and whait 45min
    4- turn key off
    5- remonve connexion
    6- start the car
