    sdnatlst's Avatar
    Aug 2011
    England
    Default ford focus 2010 cluster - how to program replacement
    hi guys, have a customer with cluster failure on ford focus 2010 year,
    usual reworking did not repair it this time so needs new cluster,
    if i get same cluster from same year car, how do i go about programming it in? what tool can do it? will mileage etc, all tally up once coded in or is that an extra job? thanks!
    Tools owned -
    exxl's Avatar
    Jun 2009
    Bosnia-Herzegowina, Bos. Krupa
    Why not swap eeprom and flash content from ori to donor dash? Or if same numbers just eeprom
    Poslano sa mog SM-G975F koristeći Tapatalk
  3. The Following User Says Thank You to exxl For This Useful Post:
    sdnatlst (14th October, 2020)
    sdnatlst's Avatar
    Aug 2011
    England
    My part number is 8v4t10849fj ,, can i replace with part number 8v4t10849fk ?
    Just eeprom would work or need both flash and eeprom?
    Tools owned -
    Meat-Head's Avatar
    Take both sets apart, look for the BDSM connect points 4 wires, get numbers off processer
    then suck and blow done a few
    ehen you read and ‘see nothing ‘ before you pannic scroll down the pages of hex
  6. The Following User Says Thank You to Meat-Head For This Useful Post:
    sdnatlst's Avatar
    Aug 2011
    England
    Cheers, got data from my broken cluster flash and eeprom, ordered the second used part, will pop the flash and eeprom on and see how it goes!
    Tools owned -
  8. #6
    Meat-Head's Avatar
    Although ‘useless’ save the data out the used clocks. Just incase difference
    then 1/2 chances can be useful if in trouble.
    feel free to write in this thread
    https://www.digital-kaos.co.uk/forum...5376-OBDMASTER
  9. The Following User Says Thank You to Meat-Head For This Useful Post:
