Results 1 to 8 of 8
    Oct 2020
    Default Hi. I need to delete these two errors P0102 and P0113 FOCUS 1.6TDCI
    FOCUS 1.6TDCI
    Hi.
    I need to delete these two errors P0102 and P0113. Can not delete them, who can help me?
    PCM 8M51-12A650-XC-8XXC SW 1039S27540 0281015242
    Gammoudi's Avatar
    Dec 2017
    ECUS
    POST FLASH MATE
  3. The Following User Says Thank You to Gammoudi For This Useful Post:
    AHVAUTOTEST (16th October, 2020)
    Oct 2020
    Default FORD FOCUS G8DA
    momogsm's Avatar
    Just Say Momo, I Will Be Here. ��
    Here You Are
    Report Back
    IF I HELP YOU DO NOT FORGET TO CLICK ON THANKS AND REPUTATION
  6. The Following User Says Thank You to momogsm For This Useful Post:
    Oct 2020
    the errors are gone but Does not exceed 3000 Rpm.
  8. #6
    momogsm's Avatar
    Quote Originally Posted by AHVAUTOTEST View Post
    Of Course, Disabling Error Will Not Solve The Problem, You Should Check The MAF Sensor, Or Make A MAF Off,
    Regards.
  9. The Following User Says Thank You to momogsm For This Useful Post:
    AHVAUTOTEST (21st October, 2020)
  10. #7
    I would check the wiring of the Maf sensor. Because both the Maf and the Intake air temperature sensor report open circuit.
    Maybe a disconnected connector?
  11. The Following User Says Thank You to oldford For This Useful Post:
  12. #8
    Oct 2020
    The problem has been solved, all 4 glow plugs have been burned.The engine works perfectly
