Meriva B 2011
14xer engine
ecu Delco E83
Org ecu death, component burned inside.
Replacement ecu, i changed vin, and changed pin using FVDI, succesfull.
Still it does not start, or allow me to program it to the bcm.
There are no dtc in bcm.
Only dtc in ecu.
P0513 immobilzer key incorrect
P0633 immobilzer key not programmed
P1631 immobilzer wrong signal
P0315 crankshaft pos,,
P080A clutch posi not learned,,
I erased and reprogrammed the 1 remote key.
That did not change anything.
Opcom clone, does not have a programming option for bcm, neither does fvdi.
Launch easydiag, no prog options.
