Results 1 to 15 of 18
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Default Mitsubishi ASX 1.8 2014 DENSO 4N13 ECU KTAG 2.25 CAN READ?
    I have to read an ecu from mitsubishi asx 1.8 2014 model with denso 4n13 ecu,
    As i can see in kess 2.25 is not available, it exists only in ktag, have anyone read it in bench
    With ktag clone?
    Thanks....
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    I tried to read it, at 26% I lost communication and since then I can not reconnect with the ecu, fortunately in the car I have a check,
    how else can i read this ecu?
    Flex bench mode without problems.
    Apr 2016
    Quote Originally Posted by Panathaole View Post
    only genuine tools, DFB do this in fullmode from pinout
  5. The Following User Says Thank You to eculevel For This Useful Post:
    Panathaole (22nd October, 2020)
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Pcmflash works on that ecu?
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Today trying with dimsport, it read it once with errors, and can't connect any more.....(fortunately ecu work fine)...
    Is this ecu so hard to read? (R4F70580SV)...
    Feb 2012
    Dubrovnik
    Ktag 7.020 works well this ecu
    The best way of being grateful is touching the button thank
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by beltronics View Post
    have you ever try?
    (i had read denso ecus with kess and with ktag without a problem in the past...)
    the ecu have this chip
  10. #9
    Feb 2012
    Dubrovnik
    I did that ecu 3 or 4 times
  11. #10
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    yes, i use that protocol, ktag make identification and start reading, and at ~30% it lost connection, i resoldering better the wires, and try again, but this time no communication with ecu....i send it to read by a dimsport, they use adapter, manage to read one time with errors, and that's it, no more communicate with ecu.....
    fortunately the car starts..... no damage to dump....
  12. #11
    Feb 2012
    Dubrovnik
    Your ecu will be wrong, I did work without problem.
  13. #12
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Ecu works fine on car, as i see the protocol for pajero is from 2006, maybe this one have different chip, as it is 2014 model, i had read many denso ecus without problem,
    I don't know what is going on....
    Even ori dimsport couldn't read it....
  14. #13
    Aug 2018
    East Pole
    That ecu has corrupted mcu. Like those z17dt denso opel or like z19dt opel bosch bulsh*t... it works on the car but cannot communicate, or viceversa.
  15. #14
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Car goes to a know in my country tune company, they try to read ecu obd, and guess, they did not make it, (they say to owner that i destroy the ecu, that's why they can't read it....)
    Official mitsubishi diagnostic tool connect correctly with the ecu........
    Is any change to read it?????
  16. #15
    Aug 2018
    East Pole
    Uhhhh... your #10 post shows that ktag cannot see all details of the ecu. Or is happening for an internal mcu issue, or becouse is not the propper protocol to read it. Did you try galletto or mpps, or some other tool?
  17. The Following User Says Thank You to volorucinski For This Useful Post:
    Panathaole (26th October, 2020)
