Results 1 to 15 of 25
    Mar 2017
    Default Suzuki sx4 2008 and dolphin
    so I have akl situation and use search button this time and not find answers....
    I disamble driver lock and find 7 bitting and with Dolphin make key BUT when i get on Suzuki sx4 hu133 key I have 10biting for cut...I put on last tree mark 1 and cut key...key open driver lock fine...but customer says that ignition lock go hard and difficult take key out....maybe is lock with 10 bitting??? or is in dolphin some errors.
    is there some advice because don't know where to see or check ignition lock how many bitting is inside.
    thanks for your time.
    May 2020
    Quote Originally Posted by hitechservis View Post
    perhaps you could take it out if it turns at all and check the bittings.
    Those locks often have some wear... If you have something like sandpaper use it on flat sides near top of blade to simulate a bit of wear.
    You could also force it a few times in lock until it starts turning normally.
  3. The Following User Says Thank You to turismou For This Useful Post:
    hitechservis (22nd October, 2020)
    Feb 2018
    10 in ignition lock and 7 (missing 1,9,10) in drivers door .
    Mar 2017
    Quote Originally Posted by Jimalex View Post
    I didn't won't to hear that...big thanks...need to take down ignition lock...
    May 2020
    This is what instacode tells me. It says 6 bits in drivers door but you found 7. Could you share the bits the way you put them in dolphin software, I could use search function to try to find remaining ones.
    Feb 2018
    what depths did you read from the door lock?
    Mar 2017
    later I will post what I find in driver lock..
    Mar 2017
    here is pod
    but today when i put on dolphin my code there is diferent cut??? now i don't have first key wich I cut first time...
    any help I will be extra good
  10. #9
    May 2020
    Ok here I am, If we say that the elements that are missing are 1,9 and 10 your bitting would be: 2124242421.
  11. The Following User Says Thank You to turismou For This Useful Post:
    hitechservis (23rd October, 2020)
  12. #10
    Mar 2017
    Quote Originally Posted by turismou View Post
    thx i will try like this and post red.
  13. #11
    Mar 2017
    for now i cut key.
  14. #12
    May 2020
    for now i cut key.
    This looks much more like a key than what dolphin first showed. Pls write if it worked, I'm curious.
  15. #13
    Mar 2017
    i will for sure..but tomorow.
  16. #14
    Feb 2018
    You cut this (1111242424)and work in the door lock??
    The code turismou give you will work.
  17. #15
    Mar 2017
    yes on door lock work
    i have today recive mechanic code from car authorized dealer mechani code and i cut key but i cut hu87 like is in dolphin data base and door lock not opened not even ignition lock....but i put in dolphin hu133 and this one turn ignitio lock but door lock NO??????
