Results 1 to 4 of 4
    epicsabi's Avatar
    Budapest
    Default Mini Cooper 171HP ecu
    We received a Mini Cooper 171HP. The owner said that they tried to update software at another service center, but the process did not complete successfully.
    I was thinking of replacing a complete flash in the ECU. As I know in this type, the immo data is in the flash.
    I have found such an ECU complete flash and eeprom on DK.
    Could you help me to write the ID's and Immo data from the original ECU data into the data what I downloaded from DK?
    The original and the downloaded from DK in the attachement.
    Bosch MED 17.2 0261201969 SW: 1037390364
    If I help you don't forget press the THANKS and REPUTATION buttons
    epicsabi's Avatar
    Budapest
    Nobody can help me?
    Member negrete's Avatar
    Jan 2020
    México
    Default mini med172 ori dump.
    virus in your archive.
    epicsabi's Avatar
    Budapest
    Quote Originally Posted by negrete View Post
    Thank you friend
    My file size is not same with yours
