Results 1 to 2 of 2
    venceslau's Avatar
    Dec 2018
    North America
    Default E46 Cluster K-BUS Fault
    Hi all, I have E46 Cluster with KBUS fault code and KBUS functions are not working.
    I tried replacing the elmos chip and compared the chip voltages at each pin from a known working unit and everything looks ok.
    The cluster is from a 2003 330Ci with the revised cluster.
    All help appreciated. Thanks in advance
    Sent from my Redmi Note 7 Pro using Tapatalk
    venceslau's Avatar
    Dec 2018
    North America
    [SOLVED]
    Elmos chip I swapped in was also bad. Put third donor elmos chip in and everything is back to good working order.
