Hello everyone on DK, i have a chevy sonic with a cluster mileage issue. when I open the ignition switch, it shows the mileage and changes back to ------- dashes. the previous shop had replaced the cluster and used BCM. that had not worked for them, so they put everything back, original. So, we ordered the new BCM and reprogrammed and reconfigured it. again, the same. the bcm has the correct mileage, but the cluster shows 0km. when it came in, it was showing both places the correct mileage. but would switch it back to the dashes right away. i reprogrammed the instrument cluster. nothing has changed. the car has the original cluster and a new bcm. when it came in, the bcm and the instrument cluster had the same mileage. when i hade programmed the new bcm, now the bcm has the correct mileage and the cluster has 0km in the ECU identification section. now, when i open the ignition switch, it is showing dashes all the time. i even tried to reprogram the ecm, but shows it has the latest calibrations so no need to reprogram it. the other shop had tried to swap the cluster and the ecm and no luck. so, everything on this car is the original. can anyone help me to figure out this issue????? the problem has started from swapping the ecm, some sort of no start diagnosis, which was wrong diagnosis by the other shop, and everything went crazy from there.
