hello guys anyone can remove immo from this ecu and actually have a full rpm working?
TO TUNE OR NOT TO TUNE
original ecu on this car was sagem s200-28 , because i cant find anywhere this ecu i found an sagem s2000-2a this file is from the 2a ecu. i made an immo off and the car started but i delete the p606 code and car revs normaly and drives good but i cant program any functions on this ecu no fan no nothing, and after i deleted the dtc a couple of times because i hads to disconect the battery , now when i delete dtc the engine light desapears but it want start
alexandrosts (30th October, 2020), Funkyusername (8th April, 2021), vladzaj67 (1st December, 2024)
unfortunatly i still have the same issue
no more that 3xxx rpm and after i delete dtc it dies no start
test this one........................
need help
now my goal is to buy xp-005
who will help?
alexandrosts (30th October, 2020), djallalouar (20th December, 2022), Ismael2020 (15th February, 2023), motohacker84 (9th April, 2025), Oxidoferroso (31st July, 2023), vladzaj67 (1st December, 2024)
Yes this solution worked 100% thank you both guys for the support
robert1232 (30th October, 2020), timzaza12 (8th April, 2022)
hi dear
can u give me the pass plz i had the same issue
many thanks
Your immo off. Thanx+Reputation and pass prive
Ismael2020 (25th February, 2023), maher1800 (25th April, 2023)
Hi!
I have a Sagem S2000-2a from peugeot 206.
I want immo off, but i not have F3-F4 wire.
I trí few slution, but not works.
Please help me. Thank you!orig_pug.rar
Attached original dump.
Your immo off. Thnx+Rep=Pass Pm
endru14 (4th June, 2024)
