Results 1 to 13 of 13
    Apr 2016
    uk
    Default Toyota key cutting code
    Hi, I have a Toyota auris 2013.
    I need biting from 79QVP
    Sent from my MI CC9 Pro Premium Edition using Tapatalk
    Mar 2018
    UK
    EU models doesn't have code stamped on the lock - Use lishi
    Apr 2016
    uk
    Quote Originally Posted by Manta1600 View Post
    Code is not from ignition but is coming from dealer.
    From all toys I have this is the only one I'm missing.. should be toy51 or va8
    Apr 2016
    uk
    Someone with instacode maybe can help?
    Need biting from Toyota key code :79QVP
    Mar 2018
    UK
    Yesterday I had EU Prius 2010 AKL TOY48
    I Decoded the lock many times but the Insta showed that this bitting is not existing
    I take out the door lock and there was code similar to your code so maybe this is key code but Insta don't know them
    Finaly I cut the key with my decode and was OK - For the first time I faced Toyota bitting that Insta dont know it
    About your Auris if the model is 2009-2013 smart key the blade is TOY48
    if is new shape 2012 onward smart key the blade is TOY40
    if is regular key must be VA2
    Apr 2016
    uk
    Toyota auris 2012+
    Is bladed key.
    I decoded the door with va6. Cut the blade,works fine in the door but not the ignition. Thought someone changed the door or ignition.
    Decided to decode the ignition.
    Will get to a point where I can't go forward,all springs.
    Tried va2 still no joy.
    Then thought is va8 and cutted a blade under va8 with 8 cuts.
    Now the blade gets very deep in the ignition.
    Has to be va8.
    I've got the code from the dealer.
    I only got 2 missing bits..
    Mar 2018
    UK
    Did you pick the ignition with VA8?
    is the decode on the VA2 is the same like on first 6 bits like on VA8?
    Apr 2016
    uk
    As I said, I'm missing the va8(toy51) from my lishi collection.
    I've cutted a va2 blade with bitting from va6 + I've added 2 cuts randomly just to make sure it's va8.
    With va8 cut the blade will go in the ignition much deeper than the va6 cut.
    Mar 2018
    UK
    I have VA8 but never had lock to check it
    Dec 2010
    Nottingham
    instacode does not have these codes , someone with silca futura may be able to help as silca futura software has some of the codes but not all .
    failing this
    lishi TOY51 tool
    remove ignition and strip
    Netherlands
    instacode does not have these codes.
    Ask someone who has a keyline / silca machine.
    They do have the correct key card.
    Mar 2009
    Instacode will be adding these to next update I hear. Very big number of combinations, making it problematic to add.
    Futura doesnt have all the codes.
    Lishi easiest way.
  13. #13
    Apr 2016
    uk
    Thanks everyone but I had to leave this one..
    Anyway I've ordered the pick for this va8/toy51.
