    Sep 2018
    Default RNS 510 COLUMBUS 3T0035680A H05 SW2684 MPEG ERROR S29AL016
    No picture, only backlight, unable to enter Botloader mode
    Changed content of S29Al016 from version 1T0035680C H06
    The radio starts up but there is an MPEG error
    The screen as in the attachment
    An attempt to load any version of the software ends with SWL ERROR (EcuOrder.txt Error reading HW Vers)
    Erasing NAND and loading software - the same effect.
    Can someone send the file to: S29AL016
    and also best for: ST10, 29F400 for this version of the motherboard?
    Thank you and best regards
    Oct 2018
    Quote Originally Posted by kozik333 View Post
    Have HW:03SW1200 from VW rns510 if you need ?
  3. The Following 3 Users Say Thank You to Mikle1 For This Useful Post:
    audiopoint (10th November, 2020), darekpola (7th November, 2023), vavrich (24th June, 2021)
    Sep 2018
    Quote Originally Posted by Mikle1 View Post
    Thank you. I will inform you about the effects
    May 2009
    croatia
    hello sir did you repair unit i have same eror like you thanks a lot for help and replay
    Jun 2021
    Macedonia
    Hello
    I have same MPEG error my unit is 1T0035680B H03 SW 0900, touchscreen doesn't work, is working while updating, I try version 5238 and 5274, after update touchscreeen doesn't work again.
    Try bins forom H11 SW 1200 bur no change after update.
    Which flash or ST I have to program new bin and someone have correct bin files ??
    dec123ua's Avatar
    Nov 2015
    Kiev, Ukraine
    Quote Originally Posted by cacko85 View Post
    Dont touch ST10 MCU, Please read datashit for all BGA chip onboard :-) before kill unit
