Page 1 of 3 123 LastLast
Results 1 to 15 of 36
    Nov 2020
    Default Problem with writing eeprom. Verify error
    Hello! Have problem with writing on eeprom 24c04 Honda Click 125cc 2012-2014. Can read, erase, when i write, it looks like successfully, but when Verify, appear "flash check error address: 0h" and when read again, can see that dump like mix of new and old dump, some bites changed, some not.
    I use USB programmer CH341A with clip.
    Yesterday i successfully without any problems wrote different dumps on another eeprom (bike dashboard same same model).
    I have found similar old topics on this forum and these are proposed solutions:
    1. Shorten cable. Lengths of cable (from programmer to eeprom) to long. But it works with another eeprom.
    2. Set voltage (is it possible to set it on my device?)
    3. Contact not good - unsolder eeprom.
    Are there another solutions of this problem? mb in software?
    Hope for help, thanks
    Problem resolved by new eeprom.
    Jardel's Avatar
    Jun 2020
    Brazil
    The best way would be to remove the eeprom and record from the outside. It may be conflicting with processor.
  3. The Following 2 Users Say Thank You to Jardel For This Useful Post:
    esse (10th November, 2020), Jackfruit (10th November, 2020)
    Lift 7 pin or better way desolder chip 10s job
  5. The Following User Says Thank You to yokazik For This Useful Post:
  6. #4
    Nov 2020
    Quote Originally Posted by Jardel View Post
    But i modified before absolutely similar dashboard, didnt have conflicts, what do u think about it?
    Jardel's Avatar
    Jun 2020
    Brazil
    Perhaps a small difference in tension, a small tolerance, allowed us to do it earlier. It may have been just a coincidence. If pin 7 is connected to the Vcc, it activates the write protection. When I do it, I remove the memory. Is it Visteon too?
  8. The Following User Says Thank You to Jardel For This Useful Post:
  9. #6
    Nov 2020
    Yes, Visteon
  10. #7
    Jardel's Avatar
    Jun 2020
    Brazil
    Try to remove and write. And post the result. We are here to help you. I'm also a newbie ....
  11. #8
    Nov 2020
    Yeah, today will try and write about results)
  12. #9
    Nov 2020
    Desolved and soldered on programmer adapter, but still have same error((((
  13. #10
    Jardel's Avatar
    Jun 2020
    Brazil
    Did you try to delete the eeprom and write the original file?Or even use some other eeprom?
  14. #11
    Nov 2020
    Tried erase and write original.
    Now in dump mix of original data, new and ff
    So as i think problem can be in programmer or eeprom or software
  15. #12
    Nov 2020
    20201110_230823.jpg mb i connected it wrong?))
  16. #13
    Jardel's Avatar
    Jun 2020
    Brazil
    Is correct. Try other eeprom.
  17. #14
    Nov 2020
    dont have now another. if this eeprom not useble, can i install another? and how to choose it? just 24c04 of any manufacturer?
  18. #15
    Jardel's Avatar
    Jun 2020
    Brazil
    Quote Originally Posted by Jackfruit View Post
    As long as it is 24c04 and the pinouts are the same, you can. But I say to test another eeprom to find out if the same will happen, because it can be a problem in the programmer. You can also reinstall the program on the computer, restore it to a previous state or even ask to run as an administrator ....
  19. The Following User Says Thank You to Jardel For This Useful Post:
