Results 1 to 15 of 19
Thread: lexus is300
    Jul 2016
    Default lexus is300
    I have lexus is300 2014
    airbag module denso 89170-53370
    R5F61797
    in the dashboard I have message saying pop up hood failure and the airbag light is off in the dashboard
    I think about clear the file of the airbag module
    do you think this will solve the problem
    and I need clear file for this file if you have please upload
    thank you
    superjet's Avatar
    Aug 2018
    read R5F61797 flash out and write back
  3. The Following User Says Thank You to superjet For This Useful Post:
    salim124 (10th November, 2020)
    Jul 2016
    do you mean write it back without any change in the file
    I have read the file by obd I can write it back by obd also
    thank you for your answer
    Jul 2016
    Quote Originally Posted by superjet View Post
    superjet's Avatar
    Aug 2018
    what tool do you use,and it can write by obd?
    Jul 2016
    Quote Originally Posted by salim124 View Post
    I use smok sorry I can not write by obd
    my question I can write the file that I read by the obd or I have to read it with jtag
    because to read it with jtag if I have to lift up pin
    superjet's Avatar
    Aug 2018
    Read by obd and write use jtag
    Jul 2016
    thank I will try and let you know
  10. #9
    Jul 2016
    thank you very much
    the problem solved
  11. #10
    Apr 2020
    Toronto, Canada
    Hello my friend, i have same model car 2017 Lexus is200t and have the same problem after a small front end hit.
    No airbags was deployes , but says pop up hood activate in dash.
    Can you please explain in detail how to reset this ?
  12. #11
    superjet's Avatar
    Aug 2018
    erase eeprom,many tool is write flash file and auto erase eeprom.you read R5F61797 cpu data and wrte back.
  13. The Following User Says Thank You to superjet For This Useful Post:
    Hondasilver (12th December, 2020)
  14. #12
    Apr 2020
    Toronto, Canada
    Thanks my friend, I have xprog 6.12 .
    So i dont need a virgin crash file to write back , after erase?
  15. #13
    superjet's Avatar
    Aug 2018
    xprog 6.12,i donot use it, it can read and write R5F61797 flash file?
  16. The Following User Says Thank You to superjet For This Useful Post:
  17. #14
    Apr 2020
    Toronto, Canada
    Sorry for my late reply, My mistake. Xprog can't read R5F61797.
  18. #15
    superjet's Avatar
    Aug 2018
    do you can write?
    pass pm
