Results 1 to 15 of 19
    Feb 2013
    UK Bristol
    Default Mazda CX7 2009 2.2 diesel Adblue countdown Refill Adblue
    Mazda CX7 2009 2.2
    Denso R2AX 18881F
    275800 - 9495
    I got this car for delete dpf and adblue
    I was doing before write file this resets
    oil reset
    o2 sensor
    dpf reset
    dpf pressure sensor reset
    scr control unit reset
    scr converter reset
    After write file show message on dash Refill adblue, they was 1499 miles and after some drive is count down (currently 1470miles)
    We refill adblue to maximum top and drive more than 20miles, - doesnt help
    I was replace all heaters with low ohmic resistor (In my case whas Bulbs - 4 together) - doesnt help
    When i go to live data SCR show me 0% level
    Anybody have some knowlage, idea, trick how it sort out?
    On level check there is 4 metal rods stick on plastic (incl temp sensor on bottom) so is not mechanical float.
    My post helps you? Please Hit Buttons
    Feb 2013
    UK Bristol
    nobody cant help?
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    wrong solution
    we have solution for this
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
    Feb 2013
    UK Bristol
    i can back to stock flash, but on dash is still Refil Adblue 1470 miele, i try anything what i know like reset oil... and rest what said in 1 post but is still the same scenario, adblue refill 1470mile, when i run engine is 3 times blink Adblue injector on dahs, at the same time cluster buzzer beeps 3 times (probably is like reminder about low level adblue) and i probably problem with this.
    Is any chance skip this?
    i have eeprom backup but is created after 1rst attempt mod, after when on dash show message about low adblue, so probably data in eeprom are overwrited and wrong.
    How is looks you solution? in only flash or eeprom as well? if is only flash condition on cluster like refill adblue 1470mile and 3 times blink can be exist or must be sorted before write you mod file?
    Inquizit0r's Avatar
    Aug 2013
    Ukraine
    I can solve. Read EEPROM and post here.
  6. The Following User Says Thank You to Inquizit0r For This Useful Post:
    pocinas (13th November, 2020)
    Feb 2013
    UK Bristol
    Quote Originally Posted by Inquizit0r View Post
    Many thanks buddy, if works you dont have idea how this can help me.
    This eeprom is made few days ago, after 1rst flash mod probably with wrong solution on file.. hope is ok
    Feb 2013
    UK Bristol
    Oh GOD... dont have idea how i feel now. After many hours work... after spend lots money for solution which dont work, i feel heappy now.
    Person
    Inquizit0r help me reset my ECU, he creates eeprom reset so now on dash is nothing about REFILL ADBLUE just one CIRCLE, no warning, no beep.
    I like say again THANK YOU.
    Inquizit0r
    Oct 2023
    hi, I have a problem with adblue on mazda cx7 diesel adblue refueling light, residual km 2340, I removed dpf and adblue from the control unit and the error immediately appeared on the dashboard, I can't reset... does anyone have a solution to exclude the error from the control unit ? please help me thanks
  10. #9
    Oct 2023
    hi Can you help me I have the same problem as pocinas I can't delete the adblue refill message... I spent a lot of money but no one can solve it... thanks
  11. #10
    Oct 2023
  12. #11
    Apr 2014
    Spain
    Read EEPROM and vrite PM
    Don't forget to press the THANKS & REPUTATION button for help in the future.
  13. #12
    Jan 2014
    Ro
    please help me to reset adblue counter in ECU eeprom 93C86.
    I made all resets before I wrote mod flash to ECU and after unplug SCR unit and SCR fuse I have message with low lovel.
  14. #13
    Oct 2017
    ESPAÑA
    Default reset adblue
    Hola, buenos días, tengo el mismo problema en mazda cx7 2010 con el adblue, adblue fap y egr están cancelados, pero sigue dando un error sobre la recarga de adblue y lee 830km para limitarse.
    ¿Me puedes ayudar, muchas gracias?
  15. #14
    Apr 2014
    Spain
    Quote Originally Posted by hiperkey View Post
    Swapp readed..
    Read in 16bits
  16. #15
    Oct 2017
    ESPAÑA
    hola de nuevo
    agrego nueva lectura
