Results 1 to 9 of 9
    May 2018
    Default Citroen Jumper 2005 EDC15C7 Immo off + U1600
    Hi. I have Citroen Jumper 2005 2.0HDi With ECU Bosch EDC15C7 0281012597 Flash AM29F400BT EEPROM 35C08 all read in external programator. I need help with Immo Off and U1600 disable, file in attachments. Thank you in advance.
    Apr 2019
    Default immo off
  3. The Following User Says Thank You to piotrek7400 For This Useful Post:
    mrmial (11th November, 2020)
    Apr 2019
    immo is flash
    May 2018
    Your file is from 0281010486, I think it's 2.8l, not 2.0l. Do you think this is a good solution?
    rafal's Avatar
    UK - PL
    Quote Originally Posted by mrmial View Post
    if..............................not good
    need help
    now my goal is to buy xp-005
    who will help?
    gyapi11's Avatar
    Aug 2011
    Hungary
    Not a good solution. Ten minut I upload file .
    gyapi11's Avatar
    Aug 2011
    Hungary
    Hi. Immo+ U1600 off. Immobox disconnect.
  9. The Following User Says Thank You to gyapi11 For This Useful Post:
  10. #8
    May 2018
    Thank you very much. Please tell me did you correct the checksum?
  11. #9
    rafal's Avatar
    UK - PL
    if you are not sure - write this one................
    if check engine will light on when acceleration - write also this eeprom ( but after test )........same pass
    need help
    who will help?
  12. The Following 2 Users Say Thank You to rafal For This Useful Post:
    laostia (11th April, 2022), mrmial (11th November, 2020)
