Results 1 to 9 of 9
    Europe
    Default Zafira C wont start ADBLUE to 00
    I have problem start ZAFIRA C 2.0 CDTI TOURER
    DELCO E98
    on dash only for starting car ADBLUE FILL.
    To engine ecu nothing?? no faults ( ENGINE NOT CRANKING )
    Coustomer refill full DBLUE TO ROAD and not ok 1000km go down and than not start more.
    I maked with x431 reset oll things ( nox 1 2 ,dpf ,service ,sensors .... )
    not cranking ?
    Babos's Avatar
    Mar 2012
    You sure in ecu is original dump?
    May 2017
    maybe starter blocked ...
    reason ad blue not deactivated correct. Maybe the only do some things or the wrong things + kill dtcs.
    Europe
    OLLis original i have read file and ok
    I have swiftec adblue off now and now engine possible cranking - but car not start.
    May 2017
    Read dtcs. Tool for read, write?
    Europe
    Noo faults to noo on ecu
    only to dash refill adblue , if see with diag adblue full ..
    possible how to dash reset solution
    May 2017
    I dont speak about ecu = engine control unit.
    I told you do a scan of all.
    Estonia
    Hi. I have got the same problem. Customer had adblue fault, drove the car to 0 km - impossible to start engine. Problem in is adblue ecu - it can not see that the adblue level in the tank even if tank is full. Dash has adblue light flashing and writes "Refill adblue to start engine". Any kind of RESET wont do the job as the car thinks the adblue level is 0 L and there is adblue level DTC active. Can the situation be solved by adblue OFF software? I have Autotuner files. Attached is OBD file.
    Estonia
    Update. Found out that the adblue ecu was faulty and did not recognise the tank being full. Solved the problem by finding another good working adblue ecu with same part number 39023841, connected it to the car, put ON IGN and all the adblue messages on dash were automatically gone. Then flashed AdblueOFF sw to the engine ecu -- engine start -- no fault. Removed fuses F4 (7,5A IGN voltage to adblue ecu) , F9 (5A IGN voltage to adblue ecu), F10 (7,5A IGN voltage to NOx1, NOx2 and Particualte matter sensor), F24 (25A IGN voltage to adblue ecu) and connected back the old faulty adblue ecu just to have a working adblue ecu for future cases.
    Rear Fuse box fuses:Opel_Vauxhall-Zafira-Tourer-C-2011-2017_20180315075739753.jpg
  10. The Following 4 Users Say Thank You to gaz51 For This Useful Post:
    bajad (4th January, 2024), Hayssam1 (20th July, 2023), Lambda1 (31st January, 2023)
