Results 1 to 5 of 5
    Dec 2010
    Default please passat 1.9 TDI egr and DTC off
    hi everyone
    please friends, I need help with the DTC P3130 -P1530 off and EGR off VW Passat ECU edc15P+ 0281011201 038906019KE-SG 4898 . Thank you in advance .
    Apr 2011
    Quote Originally Posted by oui View Post
    hi everyone
    Here is file as you request. Regards!
  3. The Following User Says Thank You to Tawe For This Useful Post:
    meaux (19th July, 2022)
    Dec 2010
    thank you very much my friend Tawe for your help but after the fiash the car smokes more white than before, and after a few kelometers the engine becomes restricted and does not increase in speed and the DTC1556 appears
    Apr 2011
    DTC P1556 is low turbo pressure: P1556 Ross Tech
    Check turbo hoses, vacuums etc.. Block EGR vacuum also.
    In the mod file, it's just closed EGR via hysteresis, DTC for EGR deleted, and Hotstart fixed, so nothing of that can cause problem with white smoke and turbo.
    Mar 2014
    Romania
    Hello. Please help whit the pass. Thanks in advance.
