Hello guys, can't read Jeep Grand Cherokee 3.0crd 2005. ID read is ok i think, but Ecu read not even starting always getting same error. "Service not suported in active diagnostic mode"
Thats clone tools for you mate. I used too use MPPS V13, works pretty well for the price.
Chiptuning File Service 24/7
Thanks+Rep If I helped you!
Bmwpower530 (17th November, 2020)
TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
SPECIALISE IN TUNING DIESEL ENGINES
(DEMON DEVELOPMENT)
IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
Yhoni (22nd December, 2020)
Thanks guys. I already ordered Mpps v18, hope it will do this car . With this one v16 i did couple cars with no issue, my Bmw 530xd 2010, Audi A8 4.2tdi 2006 and VW passat 1.9 PD 2004
What are the differences between mpps v18 china and EU? I have the v18 china and works fine![]()
(DEMON DEVELOPMENT)
daffypt (17th November, 2020)
BUY ORIGINAL!!!!
(DEMON DEVELOPMENT)
OK i understand u
chrisimerk (17th November, 2020)
usually you only get that error when ecu been tuned before and the mapper has but a read lock on the file so only way to read will be bdm or get a original file and write with mpps instead
the service not supported in active diagnostic mode error is waht im relating to
regards
(DEMON DEVELOPMENT)
Bmwpower530 (19th November, 2020)
The thing I know is MPPS clone is very risky at VAG EDC16 ecus when writing,especially after 50% writing ,when doing buffer and checksum calculation I think, writing stops,then you need Ktag or VCP... Other ecus didnd have problems, but VAG edc16 never do with clone MPPS.
If helped, Rep and Thanks is highly appreciated!
USA NGC3 NGC4 GPEC2 GPEC2A GPEC4 Stage1,MDS dtc egr cat evap off,all SeaDoo watercrafts limiters and tuning.
(DEMON DEVELOPMENT)
yes, I agree, I know its not Vag, I did with clone these ones without problems, just shared for info.
regards
Bmwpower530 (19th November, 2020), chrisimerk (19th November, 2020)
