Results 1 to 8 of 8
    Nov 2020
    North London, UK
    Question Honda CBR600RR 2009 eu km dash conversion to the ml
    Hi, I am reasearching the topic of convertion speedo to the miles insted of km,
    The european model dashboard is locked to the km/h and unable to switch to ml, generally you can press reset on the Trip A and it would switch to the ml,
    My assumption if I desolder the chip, it should be 8smd 93c56 and write it with one of the dumps available on the forum that is from UK bike it shoud then behave as UK dashboard
    https://www.digital-kaos.co.uk/forum...light=cbr600rr
    Was wondering if anyone attempted this before?
    Nov 2020
    North London, UK
    The memory chip has markings S 93C56BD VH6523, I am thinking to order another 93C56B and program it just in case I make mistake
    Feb 2017
    No need to buy a new eeprom, just save your original data.
    and then write another dumps in miles, it will be ok.
    in my memory i read/write this dash with pinout onboard. The eeprom should be under the lcd.
  4. The Following User Says Thank You to Kanni2004 For This Useful Post:
    xorti (21st November, 2020)
    Nov 2020
    North London, UK
    Quote Originally Posted by Kanni2004 View Post
    eeprom location is next to connector:
    Success, it did worked, flashing UK dump into the EU km only bike, was able to switch to km -> miles and back from buttons. Only one think left is to write original milage 6112ml, is there is a calculator app I can use?
    I have flashed this one from 2010 cbr600rr
    Jan 2012
    Germany
    I have this motorcycle. I cannot specifically talk about the operation you describe on this motorcycle because I never tried to put a dump that allows kph to mph and vice versa. But if I did it on a suzuki bandit and I can confirm that with a dump of a Uk motorcycle your dash will respond to the interchange from mph to kph and vice versa.
    Please hit the "thank botom".
    Cheers
  7. The Following User Says Thank You to spantor For This Useful Post:
    xorti (27th November, 2020)
  8. #6
    Jan 2012
    Germany
    the link is my thread
  9. #7
    Nov 2020
    North London, UK
    Quote Originally Posted by spantor View Post
    which thread?
  10. #8
    Jan 2012
    Germany
    Quote Originally Posted by xorti View Post
    which thread?
