Results 1 to 12 of 12
    slavax's Avatar
    Sep 2016
    Soyuz 1
    Default 2018 DODGE DURANGO SRT 68367 619AB 0 285 014 350
    Please help with this "dump" . Thank you!! I can test, the car is in the shop.
    Make: Dodge
    Model: Durango SRT
    Module: 68367619AB
    Memory: 95128
    Thanks again!!!
    juozas10's Avatar
    LT
    Quote Originally Posted by slavax View Post
    Make: Dodge
    Model: Durango SRT
    Module: 68367619AB
    Memory: 95128
    Thanks again!!!
    Hi.
    Your clear file.Try.
    slavax's Avatar
    Sep 2016
    Soyuz 1
    Quote Originally Posted by juozas10 View Post
    Hi.
    Did not work. Getting "B1BC7 - Deployment data record full " Error. Can't erase it.
    juozas10's Avatar
    LT
    Try again.
    password same.
  5. The Following User Says Thank You to juozas10 For This Useful Post:
    slavax (25th November, 2020)
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Check if not work ...
    Scripts for Multi-PROG
    Best regards.
    Dragon
  7. The Following 2 Users Say Thank You to dragon100 For This Useful Post:
    protech123 (25th November, 2020), slavax (23rd November, 2020)
  8. #6
    slavax's Avatar
    Sep 2016
    Soyuz 1
    Try again.
    password same.
    Did not work, same error. But D's file worked as it should
  9. The Following User Says Thank You to slavax For This Useful Post:
    dragon100 (23rd November, 2020)
  10. #7
    slavax's Avatar
    Sep 2016
    Soyuz 1
    Quote Originally Posted by dragon100 View Post
    It worked. Thank you D!! I learned something new today because I tried to clear by using technique for 2016 -17 models based on previous examples and virgin files but it did not work.
  11. #8
    Mar 2019
    dragon100 is the perfect 1 in any kind of job +100 for him..
  12. #9
    dragon100's Avatar
    Jan 2012
    Slavax , if newest Jeep/Chrysler need special cable for clear errors ...
    Best regards.
    Dragon
  13. #10
    Mar 2021
    can I get the passowrd too , please? thanks
  14. #11
    Jan 2012
    Default pass pls
    [QUOTE=juozas10;4002542]Tekrar deneyin.
    şifre aynı.
    [/ALINTI]
  15. #12
    Dec 2023
    Please tell me if it is possible to write the firmware from 68367619AB to the 68316737AA module. I can't buy 68367619AB anywhere.
