Results 1 to 15 of 17
Thread: about upa
    Jan 2012
    Germany
    Default about upa
    Hi.
    About upa programmer or how I have seen that UUPROG-S write out there.
    In a post I read that it can read S912XHY256 for dash renault clio 2017. The case is looking at the specifications of the original this mcu is not mentioned. why ?
    http://www.bhp-spain.com/es/tienda/u...full-adapters/
    How does the UPA clone work? The best version of the clone?
    Buy original from developer: elrasoft. It cheaper.
    https://order.shareit.com/product?ve...ctid=300866273
    Sent from my VOG-L29 using Tapatalk
  3. The Following User Says Thank You to mobel For This Useful Post:
    spantor (26th November, 2020)
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Upa original is a very, very good tool. Buy original don't think to much.
  5. The Following User Says Thank You to PSAcars For This Useful Post:
  6. #4
    Jan 2012
    Germany
    I am seriously considering buying original UPA. Some more places to buy reliable and cheap?
    Can you explain to me why the MCU S912XHY256 doesn't come in the list? Users here say that if you can with UPA.
    You need to inform from original site about what MCU is supported. I can check tomorow if your MCU is supported by the original Uupa-s.
  8. #6
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    I have original Upa-S from www.elrasoft.com
    It will work perfect and you could read 9s12xhy256
    http://www.elrasoft.com/uusps.htm
  9. The Following 2 Users Say Thank You to jomberykaso For This Useful Post:
    rafal (29th November, 2020), spantor (26th November, 2020)
  10. #7
    Jan 2012
    Germany
    Quote Originally Posted by jomberykaso View Post
    Great friend. Do you recommend it to me? I mean, it would be my first original tool to do more complex work beyond programming simple eeprom. My only tool has been DP3 clone, as an eeprom programmer it is vastly quite good and via odb it does some good work, but for modern vehicles it is very obsolete. I think the time has come to invest in some new original tool to program mcu (I never dared with dp3 clone). Perhaps you know of an even better tool at a similar price. Your opinion for me would be very valid.
  11. #8
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Upa is a programmer at firs place, you will need some additional programs to make your work. If you can find scripts for upa you can use them on your upa. It is very stable and reliable programmer, most of devices on list of programmer don't need lifting pins or additional work, but as I already said upa is only a programmer.
  12. The Following User Says Thank You to PSAcars For This Useful Post:
  13. #9
    Jan 2012
    Germany
    Quote Originally Posted by PSAcars View Post
    I thought that with the program that comes when you buy upa it would be enough. I understand then that there is other software compatible with upa that will allow me to improve the performance of this tool. Right?
  14. #10
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. With soft from elrasoft you will be abble to read,write,verify,erase, mod bin file manually. You can make or find scripts ( little program inside upa for calculating mileage, clear airbag and so on )for upa. But the package from elrasoft is programmer and soft to run it only. I personally like upa because it is easy to use and it is safe to use with 99% of supported mcus.
  15. #11
    Jan 2012
    Germany
    Thanks for your answers. I think I'm going to buy it. If someone has something else to wish for, I will be very grateful to hear it. I hope I can get the full potential out of this programmer. I have really heard people speak very well of it, although it is expensive for me, I think I can get the most out of it.
  16. #12
    Jan 2012
    Germany
    I am going to buy original UPA-USB Device Programmer-S. Is it possible to buy the rest of non-original adapters that have a good operation?
    I have read that you should buy the ones with osilator crystals.
  17. #13
    Jan 2012
    Germany
    Quote Originally Posted by spantor View Post
    Could somebody tell me if there is a possibility to use upa-s clone connectors with original upa-s and have an acceptable performance?
  18. #14
    You can use clone adaptors with original device, but regarding the performance it depend by the quality of your adapters.
  19. The Following User Says Thank You to mobel For This Useful Post:
    spantor (29th November, 2020)
  20. #15
    Jan 2012
    Germany
    does anyone know where to buy good quality non original upa adapters?
