    z786's Avatar
    10 Steps Ahead of You
    Default Skoda Octavia Clicking Noise
    Hi ppl,
    just a quick1 plz, skoda octavia I, clicking relay noise coming from what seems the hazard button, changed the switch but still keeps clicking, second one like this iv come across in a year, and "common faults" on this??
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
    Meat-Head's Avatar
    Quote Originally Posted by z786 View Post
    Hi ppl,
    JUST HAVING LUNCH, TRY SETTING A/C TO REICIRC, DAMM CAPS LOCK properbly a 'sniffer' mottor for a/c it 'sucks' the air in for a temp reading.
    like farting and smelling it to see if it stinks.
    (view my last post)
    If you have replaced the hazard light switch then it will be you ind stalk. Try spraying a shedload of electrical contact cleaner into it and work it up and down a few times,this may work,if not new stalk and you need to remove the steering wheel to get to it.
    DK Veteran cristec's Avatar
    Essex, UK
    Hi have you changed the hazard switch or the stalk assembly, had some of these where the stalk assembly was faulty causing the relay in the hazard switch to click rapidly but not flash the indicators.
    The hazard switch is also the indicator relay.
    I think MeatHead is thinking of the re-circulation door actuator making a clicking noise when the internal gears are stripped.
    HTH
    Semper in Excreta
    z786's Avatar
    thanks lads, will hav a go 2moz or by end of the week, will post results
    @MH
    'permitions'
    Meat-Head's Avatar
    oh yeah, was under pressure earlier.
    agree with othe rposters on hazards relay clicking
    slowly work the indicator switch up then down before you go any further
    pug's do this out 5000 pugs with this fault only 1 has cured with UB40 the other 4999 just semt to pour out white smoke!
    cristec, was thinking of the a/c sniffer but said re-circ like you said for the "blender motors"
    <peach>
