Page 1 of 3 123 LastLast
Results 1 to 15 of 33
    Jun 2017
    Bulgaria
    Default Golf 4 1.4 immo off
    Hi all,i need immo off file for BOSCH 0261206140 036 906 032 ,95040 dump attached
    publiperro's Avatar
    Apr 2016
    España
    here you have it friend, do not forget to thank you if it was worth it.
  3. The Following 2 Users Say Thank You to publiperro For This Useful Post:
    4i4o (1st December, 2020), master149 (10th June, 2024)
    Jan 2019
    your file BOSCH ME 7.5.10 immo off
    pass in your pm
    thanks and rep plz if it help
  5. The Following User Says Thank You to Andreastech81 For This Useful Post:
  6. #4
    Jun 2017
    Bulgaria
    Thanks for quick response,i will test and post result.Do i need to cut wire from dash?
    rafal's Avatar
    UK - PL
    Quote Originally Posted by 4i4o View Post
    cut all wires
    - no engine light
    - no fuel problem
    etc
    ------------ joke ---------------
    need help
    now my goal is to buy xp-005
    who will help?
  8. The Following User Says Thank You to rafal For This Useful Post:
    Staraplanina (4th December, 2020)
  9. #6
    Jun 2017
    Bulgaria
    Both files not working
  10. #7
    Jan 2019
    my solution is tested on VW Polo 2003 with BOSCH me7.5.10
    Can you give little more infos ??
    what was the problem from the start with that car ??
    Car start and run for 2 sec and then stop ??
  11. #8
    Jun 2017
    Bulgaria
    Quote Originally Posted by Andreastech81 View Post
    Yes,starts for 2 sec and den stops,key blinks on dash
    My friend try with emulator,not working.
  12. #9
    Jan 2019
    95040 BOSCH ME 7.5.10 ...
    that is the correct immo off almost for all VW grp with Bosch ME7.5.10 with 95040
    < Lambda1 infos and writing >
    https://www.digital-kaos.co.uk/forum...-5-10-IMMO-OFF
    post #8
    "Adress:12 = value 01 -> 02
    Adress:22 = value 01 -> 02
    = immo off
    1E = value which is present -1 = new value
    2E = value which is present -1 = new value
    = CHKS correct"
    check the files at HEX cmp to see if all correct
    P.S key light has to be covered
  13. The Following 2 Users Say Thank You to Andreastech81 For This Useful Post:
    4i4o (4th December, 2020), Elektrik001 (18th October, 2023)
  14. #10
    May 2017
    Nice you copy my post mate .
  15. The Following User Says Thank You to Lambda1 For This Useful Post:
    Andreastech81 (2nd December, 2020)
  16. #11
    Jan 2019
    i try to explain how IUDv3.2 do immo off, but i saw you already did in other post ....
  17. #12
    kiszka's Avatar
    all served on a tray
    now for someone to do it
    such a simple thing and so difficult
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
  18. #13
    Jun 2017
    Bulgaria
    Original file was readed with Willem,could be bad read?
  19. #14
    rafal's Avatar
    UK - PL
    if off done ok so car must start
    if not starting - other problem with car or ecu bricked
    need help
    who will help?
  20. The Following User Says Thank You to rafal For This Useful Post:
  21. #15
    Jun 2017
    Bulgaria
    post #8
    = immo off
    = CHKS correct"
    I check the files,both files that you and publiperro send me are correct according original file that i post.After two test car dont start.I noticed that data on eeprom is changed,i write immo off file that you send me and after test is back the same data,different from original.
