Results 1 to 9 of 9
    Mar 2018
    Default IMMO Off passat b6
    Hello.
    I have a problem with a passat b6 steering column lock. I have error on it, tried to change the microswitches in it, doesn't solve it.
    If i try to start the car, engine start, run for 1 second and turn off.
    I cannot change the steering column lock now, and the car is not usable until i do.
    Is there a way i can do immo off and use the car? Can someone help me with immo off? What should i provide?
    I have kess, vag commander 3.6 and vcds.
    brend's Avatar
    Oct 2015
    Same where
    Which one ecu this car have.
    And for get dump from ecu this tool like kess, vag commander 3.6 and vcds no help you,kess only fuel map,3.6 /vcds nothing.
  3. The Following 3 Users Say Thank You to brend For This Useful Post:
    ktutza2006 (3rd December, 2020), rafal (2nd December, 2020), yongblach2 (3rd April, 2025)
    Mar 2018
    edc16u34
    Main problem now is that with vcds it shows 0 programmer key
    Is there a way of getting the immo pin with the tools I have?
    Also, what I need to read dump from ecu?
    brend's Avatar
    Oct 2015
    Same where
    Open brauser and use search button for get clear information how it's go!
    And after when you get this you known what you need and can you this to do or not.
    Quote Originally Posted by ktutza2006 View Post
    edc16u34
  6. The Following User Says Thank You to brend For This Useful Post:
    immokill's Avatar
    Jun 2009
    UNIVERSE
    You can do immo off , there is solution to bypas sterring lock search on DK you need to conect brown and another wire wich is ground signal .
    But you need programmer like x prog etc . to read eeprom 95160 from ecu . Search solution is on DK
    Here to HELP!
  8. The Following User Says Thank You to immokill For This Useful Post:
  9. #6
    Mar 2018
    Ok, so after a bit of searching, I found that one of these should do the job of reading the eeprom:
    - Carprog
    - FVDI
    - BDM100
    Which one should I choose?
    From what I found FVDI could do it via ODB. Will this work? Is faster than desoldering the eeprom.
    They are clones for sure, would this be an issue?
    New findings: How to use cheap CH341A programmer for read/write 95xxx Eeproms (digital-kaos.co.uk)
    I have a CH341A around, will try to modify it as per the post and see what I can get. In case of no luck, will purchase one of above and read with it
  10. The Following User Says Thank You to ktutza2006 For This Useful Post:
  11. #7
    Mar 2018
    Ok, so I manage to get the dump, and attached it.
    Please help me with pin and immo off.
  12. #8
    rafal's Avatar
    UK - PL
    pin: 35986
    cs: D7A00CAFAF4000
    mac: 46CC1277
    need help
    now my goal is to buy xp-005
    who will help?
  13. The Following 3 Users Say Thank You to rafal For This Useful Post:
    angelito20 (9th March, 2023), ktutza2006 (5th December, 2020), yongblach2 (3rd April, 2025)
  14. #9
    Mar 2018
    worked like a charm, thank you!
