Hallo guys,Can i Swap the eeprom only to klone this ECU ? ECU type is MAGNETI MARELLI 036906 034 GN, 1AW4M.GN.
or i need to swap the eeprom and flash ? Thanks guys![]()
two different engines impossible to be the same SW
Reality of life :
1:Never argue with an idiot, he will drag you down to his level and beat you with experience
2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
3:Jealousy is a sign of inferiority
4:Everyone lies
How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
If you like to read garbage, don't slow down, just speed up
thanks , but how i can to know if they have same sf ? and when is not same sf how i can clone it ? thankss
Your photo is poor quality. If both ecu´s have same part number 036906034GN (MM4MV), just copy eeprom. Or take out from damaged und put to spare ecu. If partnumber of spare ecu is different, but MM4MV also, just copy eeprom and flash. Or take out both and put to spare. If your spare ecu is other type, like MM4LV for example, just forget it and buy other ecu, best same part number. :-)
Greets MR...
Reality of life :
4:Everyone lies
