These are pictures of a read info of the cluster with LAUNCH from Fiat 500 2015.
The odometer blinks, and i don't know if replacing the cluster will solve this problem.
Thanks for your guide.
Flashing odometer is a syncing problem between dash, ecu etc. You need to run a proxy alignment using fiatscan
Sent from my SM-G950F using Tapatalk
cristi5075 (6th December, 2020), junmab (4th December, 2020)
In at least 2 cases before i replaced clusters of Fiat 500 (2014 and 2016) and i didn't need to sync them. I only had to write the old km.
In this case, the client says it happened after removing the battery, so i installed a used cluster but the km keeps on blinking with the replacement cluster, so i can assume the problem is not the cluster.
What is flatscan ? Is it a SW or is it a Fiat tool ?
Thanks for your advise.
You asked for a solution, spottyman79 gave you the solution. Make proxy alignment.
If i helped you with your problem, please press the Thanks button.
Ask your questions in the forum, no response on private messages.
The only OBD tools i got are:
Launch 431
VCDS
DashCoder 4
Is one if these above tools is capable of making the proxy allignment ?
launch 431 i don t know but vcds and dashcoder no
for this job fiat multiecuscan with OBDlink SX
BR
junmab (6th December, 2020)
Hi. Try launch. Or if you have a friend with fvdi abrites. It takes 1minute to do it
Just about any decent automotive diagnostic tool will do proxi alignment .
esse (6th December, 2020), junmab (6th December, 2020), Staraplanina (6th December, 2020)
My autel does this as I had the same issue late week , launch may possibly do it also , as above , it takes 2 minutes
