Results 1 to 1 of 1
    exxl's Avatar
    Jun 2009
    Bosnia-Herzegowina, Bos. Krupa
    Default bmw e65 dde master and dde slave to cas sync problem
    i have following problem, after battery disconnect and reconnect master dde and slave dde has got out of sync with cas, with abritres i resync master ecu but slave ecu will not sync, i tried also with inpa and rheingold but slave ecu will not sync.
    car starts but works only on 4 cylinders since only master ecu is sync with cas, can somebody sync in dumps slave ecu to cas or repair to virign state somehow slave dde eeprom so i can try again to sync with rheingold or abritres.
    dumps are attached
    b.r
