Results 1 to 3 of 3
    Default Mercedes C class A205 900 8618 Collision Prevention Assist Plus?
    Hi can anyone offer any advice on this?
    Can't get rid of this fault code
    B1C32-00 - SRS HAS DETECTED A CRASH. THERE IS A GENERAL FAILURE - CURRENT AND STORED. fault located in the collision prevention system.
    ecu has been reset, airbag light goes out no fault codes present but collision avoidance system fault comes up on dash and above fault code appears in that system.
    If I disconnect airbag ecu then scan collision system then B1c32-00 fault still appears.
    Has anyone every reset this fault?
    slick_dick's Avatar
    Essex
    clear crash using star/xentry
    “There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
    Oct 2013
    You need to go to collision prevention system and use a good scanner to clear the crash memory.
    Hope this helps!
  4. The Following User Says Thank You to qubits For This Useful Post:
    mati1234 (12th February, 2025)
