Results 1 to 15 of 15
    chrisimerk's Avatar
    Dec 2018
    England
    Default Hardcut software development for opel
    Hi guys I'm testing out a hardcut/ignition cut limiter software only for opel which I'm developing for the engine code and ecu type below.
    A16LET/Z16LER/Z20LEL/Z20LER/Z20LET/
    Z20LEH
    ME7.6.2
    ME1.5.5
    Let me know what rpm you would like it set at.
    I'm only doing a few.
    Please leave a video of the effect.
    TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
    SPECIALISE IN TUNING DIESEL ENGINES
    (DEMON DEVELOPMENT)
    IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
  2. The Following 5 Users Say Thank You to chrisimerk For This Useful Post:
    centrozax1 (17th December, 2020), diags (18th December, 2020), geedot187 (26th January, 2021), peechie (7th January, 2021), Yhoni (18th December, 2020)
  3. #2
    Feb 2020
    Default Hello !
    Please help with Hardcut on my Z20LER on 4300 rpm
    I ll back with video (i have a nice exhaust ! )
    chrisimerk's Avatar
    Dec 2018
    England
    Quote Originally Posted by 99RYN View Post
    are you sure you want it that low?
    also your archive is corrupt upload again
    (DEMON DEVELOPMENT)
    Feb 2020
    Default Hello !
    I archived again, there are 2 softwares one l stock with lambda probe canceled, and one l with rev cut from 2500rpm, and from 4300rpm to be able to run in normal mode, or if it can be activated from the sport button would be a dream! The one with stage1 and revcut is not completely executed ok, at 2600rpm it cuts off the power supply and the car goes defeated ...
    chrisimerk's Avatar
    Dec 2018
    England
    i would say that rpm for ignition cut is too low mate
    (DEMON DEVELOPMENT)
    chrisimerk's Avatar
    Dec 2018
    England
    Here i modify the lambda off file hc at 6700rpm im not messing with files that are rubbish and are not working correctly
    enjoy
    pass in pm
    (DEMON DEVELOPMENT)
  8. The Following User Says Thank You to chrisimerk For This Useful Post:
    99RYN (18th December, 2020)
  9. #7
    Jun 2015
    chris, could you give me a msg please. i have a few gsi,vxr questions
  10. #8
    Aug 2020
    hi could you do my brothers astra vxr its got centre box and back box still in place but has both cats removed will this still be ok for ignition cut?
  11. #9
    chrisimerk's Avatar
    Dec 2018
    England
    Quote Originally Posted by projohnny View Post
    here test and report and yes with your centre box and back box still in place it will effect the sound and outcome of the cut. no flames etc....
    pass in pm
    dont forget to post video
    (DEMON DEVELOPMENT)
  12. The Following User Says Thank You to chrisimerk For This Useful Post:
    projohnny (20th December, 2020)
  13. #10
    Aug 2020
    Quote Originally Posted by chrisimerk View Post
    pass in pm
    thanks will get back to you shortly with video
  14. #11
    Aug 2020
    Thanks alot bro is sounds amazing its very loud i will maybe delete centre box for flames
    again thnaks alot i have attached videos of your work the videos dont do it justice tho
  15. #12
    Aug 2020
    sorry it wouldnt let me post videos here they are
  16. The Following User Says Thank You to projohnny For This Useful Post:
    chrisimerk (20th December, 2020)
  17. #13
    Feb 2016
    Sofia , Bulgaria
    Hi can someone make to my file Hardcut
  18. #14
    Jun 2021
    Can you explain how you install it on you computer?
  19. #15
    Sep 2022
    Can anyone suggest any courses so that I can upgrade my qualifications to a developer? I just recently started studying programming, and it's hard enough for me now because of the insufficient amount of knowledge in the field of development. I can code well, but not enough to get me into a good company, so I'm looking for ways to develop professionally as a specialist. I aim to get a job at the software solution provider company since these guys do big indoor projects, and I dream of being part of their team. I hope to succeed as soon as possible, but I am ready to spend a lot of time and effort training.
