Results 1 to 10 of 10
    Dec 2020
    Default Blue&Me Repair Thread
    Hi to all, at the moment i'm trying to repair the Blue&Me modules in Fiat/Alfa/Lancia. These modules die easily after change/discharge of the battery. I wanted to share what i know about their fix and hope someone know more than me can share his info. The problem is the Firmware that gets corrupted, we can found the firmware in a NAND Flash (BGA63) that is over the Micro (STA2062, a protected Micro which i've not been able to find any info about R/W it). There are a 4 types of NAND flash that we can find in these modules, 2 types are Micron (NW140 and NQ278) and 2 types are Samsung, i read and write them with TL866II (for now, without success for the repair). At our workshop now we send the bricked B&Me to someone that can fix them and after his repair i open them and i found every time the same 'repair signs' (a glue/paste around the NAND and some solder joints on the board on some test point that seems a J-tag connection). During the repair he can also change the compatibility of the module changing his Firmware (Lancia Delta can became Fiat 500/Grande Punto ecc..). I've got only one hint from him and nothing else, he does something with Martech programmer. There are the informations i've got at the moment, i hope someone knows more than me and we can share our infos!
  2. The Following 2 Users Say Thank You to Antonio266 For This Useful Post:
    adrianojeminaj9 (31st January, 2021), duzaven (16th April, 2021)
  3. #2
    Apr 2016
    Any more news to share regarding this repair? i have 51926903 to repair...
    Dec 2020
    Nothing mate, when i have time i try to do some tests but i don't have so much time. Anyway recently i've tried reballing an original Nand Flash from Blue&Me, it's not so easy, i don't have adapter so i have reballed every single ball one to one with the help of a tweezers.
    In the next days i will reprogram it if i find a good dump (this is the real problem!) and then solder it again.
    Feb 2019
    Nederland
    Martech programmer does not programm nand and cpu from Blue&me
    Interested in this ,any further development ?
    Dec 2020
    Nothing, i don't have a good dump for trying. Anyway i don't know if it's worth, now i pay €70 for repair a faulty unit, but it's also strange that i pay only €70 for a reballing + reprogramming of Nand Flash..
    italy
    Quote Originally Posted by Antonio266 View Post
    good question. only 70 euro for this job it's to cheap.
    i think it's some programmer thet can fix it without reballing nand flash.
    Feb 2013
    UK Bristol
    yes can fix without soldering but price is 2500 euro, and you can find here https://blueflasher.it/home?hl=en.. 70 euro for repair is cheap, in UK people charge minimum 150 pounds for repair
    My post helps you? Please Hit Buttons
  10. The Following User Says Thank You to pocinas For This Useful Post:
    carradio2001 (19th January, 2022)
  11. #9
    Lithuania
    any one can share ISP pinouts for emmc reading? please to pm if cant share publicly
  12. #10
    Feb 2022
    in the UK
    they are right,
    get yourself
    to pay
    handsomely
    and that others
    repairers
    they do not give
    value
    laurel
    professionalism
